Please adjust the lens up to check if it still has the problem.Okay i am uploading the footage from the same 3 minutes as above, and there is a curve ball in the lower Left corner of the footage.
it should go, looks like it's the demister strip in the glassPlease adjust the lens up to check if it still has the problem.
I think Kamkar was looking at the "27" in the bottom left corner, it should not be there.it should go, looks like it's the demister strip in the glass
I mustn't be the only one that wasn't clear on what he was referring to in that case, adjusting the lens up sure won't change the OSDI think Kamkar was looking at the "27" in the bottom left corner, it should not be there.
We have such a plan, but not sure the time.have they mentioned this being a planned option?
Danish English is sometimes hard to understandI mustn't be the only one that wasn't clear on what he was referring to in that case, adjusting the lens up sure won't change the OSD
he does quite well, better than some native english speakers that I know, if it's the 27 he was talking about that may be connected to the random Chinese characters he also hasDanish English is sometimes hard to understand![]()
English is an Anglo-Saxon language, and both the Angles and Saxons came from a few hundred miles south of Kamkar's home, his native language is close to the original English.he does quite well, better than some native english speakers that I know, if it's the 27 he was talking about that may be connected to the random Chinese characters he also has
File courrput happens under unplugging the charger or under powering off the car?
Do you always turn on wifi?
Yes it was the massive +2700 KM/h speed, if you ignore the first two digits i think it is the same as the speed indicated in the front video.
The footage look good and the way the rear camera are installed it is not as close to the glass as i use to have cameras in the back, and now i do have heater lines in the footage.
Yes my camera are glued to the windscreen with the provided mounts and sticky pads, i try to keep things as original so not to introduce failures that are out of what should be able to be replicated.
no i think wa are all on the same formware, named something like 20200515V1.0, so we should all be on V1.0 firmware.
No. But reverting to factory settings and starting over again seemed to help with the improper shutdown. Will report if the issue comes back.Do you turn on wifi?
Zenfox T3 Stuck up logo... | Zenfox | 3 | |
Zenfox U1 2-Channel Dashcam Review | Zenfox | 12 | |
New Zenfox camera i just noticed | Zenfox | 7 | |
R | Zenfox T3 insides | Zenfox | 80 | |
J | Zenfox T3 3H review - Triple dashcam for ride sharing | Zenfox | 22 |
