I guess you could contact Viofo and complain that their hardwire kit plug is upside down for use with a Zenfox dashcamStill don't like the plug on the Viofo Kit being inverted and U shaped or looping to fit. Not the most ideal arrangement.
Not sure what the response would be, they are not going to change it because then the Viofo hardwire kit wouldn't fit a Viofo camera when the rear camera is plugged in!
yet.Zenfox doesn't have it's own hardwiring kit
yet.
No it do take some to test cameras, just use it is easy to do,
but if you want to be able to provide some feedback, you need for instance a suite of different relevant memory cards so you can test memory card compatibility.
You also need to take a structured approach to using the new camera, something i am still working with myself even after all these years, and to be honest i dont always feel i do as good as i should.
But i trust if people feel i am missing out they can tell me, i think it is okay to ask such things even if you provided a free camera to someone. I am always open to suggestions on how to do a better job,,,, and be a nicer guy ASO.
Next week i will probably spend 6-700 DKkr on 2 new memory cards to my test suite, i will get a 256GB card for general use, and another 128 GB card that go strait into the tin of test memory cards.
Sandisk high endurance ( 256GB - 586 DKkr )
Western digital purple ( 128 GB - 231 DKkr )
The plastic trim on my A pillars or at least the Left hand side one are barely able to stick, there are 3 places they lock in place, but the metal thingies that do that have detached from the plastic trim and fallen down in the A pillar.
It is almost as bad on the Right hand side.
Not meant to come on and off as often as i my car.
I should get a new set and paint them flat black, like i have threatened to do for a while now.
i think it just said zenfox T3V1.0
Could be they sent out different firmwares to test them as well? Or in light of your having the Chinese characters there could be different versions such as you see with the 70mai which has (or had) Chinese and International versions on the market which were different in more than language and writing.
A tester should always be prepared.
This is my latest additions to my micro SD card collections.
Seems I'm the only one inclined to do a hardwire test with the HK3? Having already shown it works with the kit.
None the less, I'm not Mr. Money Bags. Already dropping around 92 E / 100 USD to order SD cards and Hardwire kit. Waiting a few days to have things shipped isn't going to affect much!
You're a true Beta Tester Nice SD card collection!
have they mentioned this being a planned option?I will definitely order a cpl filter from Zenfox for the front camera as soon as this comes available.
yeah it's not as simple as some of the other models out there if you want to add a CPLI'm wondering how to fit a CPL for the front camera I think a stick-on type CPL might work
T3 no GPS timer.You told me the answer I also alluded to, but without an "actual answer". We don't know if the Camera has a GPS timer function to enter parking mode. So using a Battery Pack or 12V add a fuse may not work......Viofo Hardwire kit is a non stater.
Maybe someone with the camera can chime in if the T3 supports the GPS enabled parking mode.
Zenfox T3 Stuck up logo... | Zenfox | 3 | ||
Zenfox U1 2-Channel Dashcam Review | Zenfox | 12 | ||
New Zenfox camera i just noticed | Zenfox | 7 | ||
R | Zenfox T3 insides | Zenfox | 80 | |
J | Zenfox T3 3H review - Triple dashcam for ride sharing | Zenfox | 22 |
