yeah it's not as simple
stick on won't be easily removable or adjustable. I hope is one that covers the whole lens frame. Kind of like attaching the dust cup to binoculars. That way it can be easily attached/removed when needed to.I'm wondering how to fit a CPL for the front cameraI think a stick-on type CPL might work
the type we used on the SGZC12SG might work, there was an adhesive steel ring around the lens then a mag filter which was easily removable/adjustablestick on won't be easily removable or adjustable. I hope is one that covers the whole lens frame. Kind of like attaching the dust cup to binoculars. That way it can be easily attached/removed when needed to.
I like that idea.the type we used on the SGZC12SG might work, there was an adhesive steel ring around the lens then a mag filter which was easily removable/adjustable
Just test/review with what you have on hands is good enough.
I've been testing/reviewing dashcams since 2015. But there are a lot more senior testers/reviewers in DCT. I'm just small fry
I usually wait for the cards to go sales before I buy them.
128GB has gotten cheaper over the years. Now waiting for 256GB and 512GB cards price to go down.
T3 no GPS timer.
If the T3 does not connect ACC hardwire cable, it will enter into parking mode after the G-sensor and motion detection are not triggered for 5 minutes.
I did a bit of driving this morning and camera seemed to behaving well for the moment being. I'm not intending to add parking mode capability to my unit since I feel that is not a big priority for me at the moment but I totally understand it could be to others. I will definitely order a cpl filter from Zenfox for the front camera as soon as this comes available. I today's sunny short drive the dashboard reflection was a bit too much since I am used to not see that on my Viofo with the filter on. Also looking to get some A1 or A2 sd cards soon, even though the EVO and SanDisk Extreme Plus are doing well so far, don't know for how long though.
Ya 256s are a bit pricey still, but I want a card that'll capture a day or two worth of video without fear that stuff might get overwritten. So I shelled out for 1 x 256 and 1 x 128GB Sandisk High Endurance. No big deal. I budgeted some money for the beta testing. Just not to your caliber of a hoard worth of micro sd cards!!
Hahaha... My cards is for use in all my devices in the family. Not just for dashcams.
I agree, you have a very valid reason to want to capture another posible event and hopefully with enough detail of who did or does such a thing and make him pay for itI already had some A-Hole F*CK my nice car up with a 10 inch / 16CM paperclip width scratch on my door. Front + Rear didn't capture it. Seems the Zenfox Taxi cam might be better suited for the job. Either way, doesn't fix the scratch, and I have to learn to live with it. But you own something nice, and people have no respect.
It seems the perfect size for a 52mm SLR camera CPL filter, stuck on with 3 small pieces of 3M tape.I'm wondering how to fit a CPL for the front cameraI think a stick-on type CPL might work
Why do you think that?Seems I'm the only one inclined to do a hardwire test with the HK3? Having already shown it works with the kit.
Please format the card to FAT32.Class 10 minimum.
I suggest that it is also A1 rated minimum, but Zenfox has not specified that.
Until extended testing is done with each model, we have no way of knowing if there might be an incompatibility. Zenfox probably wants the testing to find any that don't work.
Also good to test both FAT32 and exFAT, check that they work.
Do you turn on wifi?I have detected the first problem on my unit. When I start the vehicle, the camera starts normally, but then I turn the vehicle off the camera wont sense the power cut off and the screen will fade off until the internal caps are discharged resulting in corrupted file in the last clip being recorded.
If I disconnect the rear camera and I repeat the power cycle, the camera will turn on and turn off normally. Don't know if this is a power cord issue since the rear camera turns on and records just fine. the issue only happens at the time of shutting down the system. Any ideas? I was extremely carefully trying not to damage any wires while installing the unit.
Please check if you turned on wifi always.I noticed one such fade to nothing shut down too, but if it resulted in a corrupted file i cant recall / tell
I have had corrupted files 2 times now, once on first files right after boot, and once on the last files.
But it is not a regular thing at all, by far the camera perform normal,,,, but of course not used it for long time yet
I did perform a short test using a PSU from a SG camera, that worked just fine in regard to recording the 3 video streams.
But i am of course carrying on with the provided power supply, the SG one was just my only option to get the camera down on the dashboard as the power wire go to the R A pillar, and the rear camera go to the L A pillar and then put back.
File courrput happens under unplugging the charger or under powering off the car?My test unit was just delivered and out of 8 power on/off tests with a new out of package U3 / V30 /A1 rated 128GB card, 5 resulted in fading out and all 3 camera recordings were corrupted. I left the power on for between 30 to 90 seconds in case it was an issue of insufficient time to charge the capacitor, but it didn't seem to make a difference. The corrupt files for the front camera varied from 80MB to 175MB compared to the largest valid file was 437MB for 2:09. Of the ones that successfully saved, a couple were probably from me testing the power button, which seems to shutdown and save correctly. This is definitely something that needs more investigation.
On the bright side, I was very surprised at how quickly Zenfox got the test unit delivered and from outward appearances the build quality seems nice. It will take some time to see if it can hold up in the summer heat.
KuoH
Please format it to FAT32Has anyone tested exFAT?
I've had a load of files go missing once the card filled up, I think I only had the last file from each journey after the card was full. I'm guessing it has only happened because I formated the card as exFAT. A reformat in the camera has put it back to FAT32.
Choose timer on, it means the parking mode is always on.Let me clarify. Manual is wrong. It is NOT optional. If you don't enable parking timer, Parking mode does not work. At least those were my results using the Viofo Hardwire Kit.
Zenfox T3 Stuck up logo... | Zenfox | 3 | |
Zenfox U1 2-Channel Dashcam Review | Zenfox | 12 | |
New Zenfox camera i just noticed | Zenfox | 7 | |
R | Zenfox T3 insides | Zenfox | 80 | |
J | Zenfox T3 3H review - Triple dashcam for ride sharing | Zenfox | 22 |
