Hi guys i got same problem here is what i found may be it will be a clue to fix it but for now my 0803 is recording ! SOLVED !Hi,
I cannot find, If someone have same problem. It seams, that after card is full (32GB class 10), 0803 stop recording after few seconds with chime. It is still on, but not recording. If I start recording manualy, camera start, but, still, after few seconds recording stop (I mean up to 20 seconds). If I repeate this 5 or more times, it start recording without stopping. I try other card, it is same. Cards are OK, because I have 0801 too and it works without problems. If I format or clear card, it works.
I can say, that 0803 have good video, but, it is crap. 0801 without problems, but 0803 still something. Problem in battery, freezing, sometimes it looks like camera recording, but, on card is nothing, stopping recording.
Thanks, Peter
So firs thing first
I bought it about 6 month ago it was working but kind of mulfunctioning i google it and found latest firmware w0140919 plus i modified logo to toyota so it was stable and working fine (note: i dit update firmware for my friend at same time he also got 0803 plus gmc logo )
So his cam is stil good no problem mine fail , how this happen ;
Vehicle had an accident G sensor was activated , after that i start to expirence problem it was stop recording with chime sound (note using 8gb internal and it was recording to 32gb external card)since then i figure out its stopping to record when 32gb is full and no meter what settings you cjange it wont do loop recording , i changed 3 different card different brand and no luck , once its formated its ok when its full no recording i format them different way through camera and computer still same result , i find out that cam creating 4 foldets in card so in 32gb i descover that player folder missing so i copy that folder from internal 8gb card (note; by this time i already took cam complitely apart to find whats going on in there)dont do it its not going to help also i use power from base with gps and conected directly still no luck. So after all that i insert 16gb card and now i got 8gb internal and 16 external and voalya its recording already 3 days no problem ,so my guess is whatever software is inside it canot create some kind of table with 32gb to register files and its stuck at the end when its full my was even showing invaled file (note i try to load firmware again its also did not help) new card twice smaller in size helped to fix it , guys try it out with different size card and report here to see if this is solution.
Thank you and have a great day !
