I just wanted to heat up the camera and then focus it at a high temperature, so i put a hair dryer under it as it was hanging from the HDMI cable in my living room window.
But the hair dryer is a old one without a thermal safety i would assume, we have used the same dryer for decades to dry paint faster sp we can apply the next coating faster and be done with it.
So left with the 2 PCB bords was one half shell ( the front part with the MIC ) and then the ring that is the part of the horizontal adjustment.
Both "trapped" on the camera due to wires i dident wanted to mess with, so i just sort of hanged them loosly on the PCB assembly, and so they was actually longer from the hair dryer than the most of the PCB assembly, but not far enough it seemed.
The camera was also recording while this whent on, and i was on the PC keybord so i dident see the camera shut down.
So i turned off the hair dryer for a little while, restarted camera with a 68 Degree reading in the LCD, turned on the dryer again and then focused a few minutes later.
(at the time of focusing i had not noticed the plastics warping, that i first saw when i was putting it back together )
Both pieces of plastic warped some, mostly the big half part warped so bad i had to cut some of it off to assembly the camera again, but the outer ring the spring loaded steel ball click into also warped a little bit.
You can better see it on the full 12 MP picture, not much but just in the reflected flash light you can see the plastic are a little warped, and its actually worse other places but that dident come thru in this picture.
I think i can replace the front half shell with the same fron the 0608, but not something i have planned to do now where beating on this seem more important, and the camera are fully functional, but are now sagging a little in the "hinge"
