Update on 29 July
W02 Universal Car 5.5 inch Head Up Display Projector OBD II Speed Warning
http://www.gearbest.com/obd-diagnostic-tools/pp_32055.html
It is only
$37.99+Free Shipping!!
Description:
Our multifunctional HUD product is developed based on OBDⅡ interface and has good cost-performance ratio. It is designed by adopting the latest integrated circuit with stable performance and has a beautiful and elegant appearance. The installation and adjustment examination can be finished within 3 minutes by using an easier and safer method.
Notes:
1. Automatically adapt to the automobile models with OBD II (Bus Automatic Diagnostic System) interface. Check if it has the automobile diagnostic socket under the steering wheel.
2. Identify the car's 16-pin diagnostic socket, connecting the OBD II cable to the 16-pin diagnostic socket if it has this socket.
3. Put the non-slip pad onto the instrument pane, then put HUD on the non-slip pad, you can adjust the angle an position.
4. The reflective film may be affixed to the forward position of HUD and stick to the front windshield, ensuring that the information, such as car speed can be projected to the reflective film.
Main Features:
1. Plug and play, HUD can auto adapt to vehicle type which in line with OBDII or EUOBD (On-Board Diagnostic System).
2. Comprehensive display, HUD can display many parameters at the same time as follows, vehicle speed, engine speed, water temperature, voltage, throttle valve position, ignition advance angle, time of 100 kilometers acceleration, fuel consumption, mileage, low fuel tips, engine failure.
3. Diversiform display mode, driver can choose normal display mode, high-speed display mode and automatic display mode.
4. Free switch, kilometers and miles can be switched freely.
5. Suitable size, the display area is 5.5 inches which is very clear for driver to read data.
6. Automatic power on and off, starting with the vehicle starting, stopping with the vehicle stopping to protect the vehicle's battery.
7. Flexible alarm mode, HUD can offer single-stage and four-stage overspeed alarm modes to choose, making drive much safer.
8. Engine speed alarm, it contributes to shift gear in time to save fuel.
9. Flexible brightness adjustment, the brightness can be adjusted automatically or manually to reach the best state which is in harmony with the environment.
