Steve_3939
- Nov 2, 2017
- United Kingdom
What car?
A45 AMG Mercedes
What car?
Battery is supposed to last 15 minutes but lasts nowhere near that when new and fully charged. So parking mode is 50% more useless than 512GW.
It automatically goes into standby mode for me as well whilst transferring high resolution file via WiFi.
I’ve tried with parking mode off as well makes no difference. Sometimes it just crashes and freezes I have to hit the reset button. I’ve only been able to successfully transfer 3 files since I’ve had the had it usually after hitting reset button it works.
612 OWNERS QUESTION
Brought a 612gw and I must say I like the touch screen and some of the improvements but I don’t know if I have a faulty one or not but when I remove the camera from the mount it dies within 30 seconds. My 512gw has about a 30 minutes of battery life after being removed from the power. Also when transferring files it shuts down whilst in the car, again my 512gw never did this?????
Any 612 owners getting similar???
Let’s try again!
Halfords were fairly good tbh, they had to ring nextbase to get some authorisation number but they didn’t quibble about replacing it
A friend is on his third unit. It's difficult to know but the symptoms seem to be power related.
From his email I suspect he's not pushing the unit fully home as he's had a few times when it's fallen out of the mount. He reckons that when he first turns on the ignition the unit powers up. When he then starts the car the dip in power turns it off and it never recovers !
I'm suspicious as no one else has this issue. He also reckons he's has 6 firmware updates in 6 weeks !
I was intrigued to see what hardware these are based on - it appears to be an Ambarella ARM based platform with a Sony 8Mpixel IMX317 sensor, same as that used in the Xiaomi Mijia 4K camera (and from a post by @Agie the same as the Sony FDR-X3000 too).
The Xioami is paired with an A12S75- the Nextbase is also A12 based, just not sure of the exact model.
Judging by the mount and the firmware it's made by Samoon.
Don't know what these do but these files are referenced in the firmware if anyone is bored and fancies a play - please be warned these are usually service use only though - your milage may vary.
C:\LowSpd.txt
C:\SD_LOW_SPEED.txt
C:\focusing_samoon.txt
C:\Nextbase.info
C:\TEST_GPS.TXT
C:\TEST_GSENSOR.TXT
C:\LIGHT_ADC.TXT
C:\NEXTBASE_GSENSOR.TXT
C:\TP_TEST.TXT
C:\MISC\wifi.conf
Nextbase 612GW Thoughts | 612GW | 25 | ||
D | Nextbase 612GW Corrupt files when you need evidence the most | 612GW | 9 | |
L | Edit videos on 612gw | 612GW | 12 | |
612GW 'recording stopped' | 612GW | 20 | ||
612GW Parking Mode | 612GW | 7 |
