mentadent
- Nov 14, 2020
- London, UK
- United Kingdom
- VIOFO A139, VIOFO A139 Pro, VIOFO A119 Mini 2, VIOFO A229...
I'm in Oz, it's 30fps for me on the video files for sure. Not sure what's going on there...@Augustus are your video files from 70mai Omni 4K, 25fps? I believe Australia uses that standard, as does UK, and USA uses 30fps. Mine are 25fps.
Different regional, may be because mine is a different variant. Who knows. I prefer the 30fps definitely over the 25fps just looks too choppy otherwiseWeirddddddddddd
Nice easy fix 🙂It is the anti-flicker setting. I changed it to 60Hz now. It doesn't matter if some store window displays flicker as I drive past.
This is going to happen with any dashcam if you have tint on the rear windscreen.I put a 5% transparent film on the window to test if the camera sees ok, it seems it doesn't... it also distorts the light...
(Back camera)
You should let 70mai know, every little bit helps other users out there!In Denmark i use CBB that is on the TT network ( #2 largest network here )
