I've always used this sd along all my tests. This is not my first format. I do not own a 32gb card.
I did new tests. I inserted again the sd card in the unit. A119 asked me to format the sd card. Format done but always the same behaviour. REC light on, nothing recording and if I press the rec button it starts beeping and I can't stop. The only way to access menu is during the boot, in the first seconds.
I tested more and more times, my A119 was "soft-locked". I could try reformatting the sdcard with my pc or try a new sd card. I did another test: I accessed the menu at boot time and navigate all options. I modify image picture at 2k@30 fps (previously it was 1920x1080@60 fps). When exiting from menu, Viofo finally start recording again.
There are a long list of features I think Viofo should double check:
- the blinking rec red circle icon looks the only icon trustable. The red rec button light should always be in sync with this one because users are not geek and they don't double check the rec icon, they trust in rec button. And rec button light is visible during day, rec icon no, display is not so bright
- all the process schould be error free. If Viofo is not recording (that is if Viofo red icon is not showed) and user is not using the menu then Viofo should beep. If something is not working, I need to know. But Viofo will not alert me
- there is a firmware problem here. Why Viofo doesn't record and after I change image resolution it start recording? This is not a hardware problem, it's a software problem
And please consider also my previous bug: audio recording stop working and mp4 files are corrupted.
I hope a new version will be available asap with these bugs fixed. I hope Viofo will enable a debug log file for beta tester, so when we have an error we can see the status. A good idea is also generate an "image" with all data
