mealto
- Jan 26, 2015
- Canada
Yes, same GPS mount.
Sorry, mean to ask if A119 Pro cam can be mounted on an A119 V2 GPS mount.
No, the original V1 GPS mounts with the pins are not compatible with the V2 A119 series cameras.Is a A119 V2 compatible with the early gps mount, the one with the pins before they switched over to those bent back pressure type connectors? I'm still new to much of this and am not sure. It may affect if an A119 Pro can work with an early version of the GPS mount so genuinely curious.
Yes, they use the same GPS mount.Sorry, mean to ask if A119 Pro cam can be mounted on an A119 V2 GPS mount.
Thank you for confirming, I’ve been wondering about that.No, the original V1 GPS mounts with the pins are not compatible with the V2 A119 series cameras.
The GPS logger on my video is v2 it's taking down from A119S to Pro and compatible with A119 v2.Hi guys this is my Unboxing just arrived
https://goo.gl/eWh3Hm
Cool! Hey, can the A119 Pro be plugged into the A119 GPS mount?
Okay..A119S had a V1 version also
A higher fps will not always give you the better detail that you are looking for. It does increase the chance that a passing car will be in the focus sweet spot.Based my experience, a Dashcam should support minimum 1080p 60fps higher fps will be much better (120fps, 140fps, 160fps). Car running only 40km/h is hardly to capture the plate number, if the car running more than 100km/h is require higher more fps and better resolution and sharpness and not compromise the night view.
As long as you prep your windshield properly I guarantee you that it will never fall off.eventually the 3M double sided tape will not stick to your windshield for long.
So it there a newer firmware out for the A119 PRO yet?
If you remove the camera from the mount many times, the tight fit might become loose. Then you should apply one of the supplied foam pads to the mount to maintain a firm support to the camera.I think the sliding mechanism of the mount is not designed for many uses. If you take the dash cam off and on many times, eventually the 3M double sided tape will not stick to your windshield for long.
LDWS: OFF (What is this?)
FCWS: OFF (What is this?)
Frequency: 50 Hz (Should I set it to 60 Hz?)
