Boot loader installs fast. Lights don't blink like when installing firmware. Did you reset defaults after the install?Upgrade downloader I didn noticed, rec do not blinking, maybe because file is too small and upgrade run too fast
Problem as on the movie :
What has happened ?
What 64GB SD cards are known to 100% work with a119 firmware ver 2.0 ?
First of all, you should NEVER insert or remove the SD Card with the Dashcam powered on.
Put the .bin file in the root directory of the SD Card. Insert the SD Card in the Dashcam. THEN power the Dashcam on.
RodeoGeorge
Edit 8/24 to clarify.
Format the SD Card in the Fat32 format. Then place the .bin file in the root directory.
I have not tried placing the .bin file on the SD Card without first formatting it.
It will corrupt the last file is it was recording. If not recording then probably nothing will happen.What can be damage when u remove SD with the dashcam power on ? only SD card ?
For corrupted files, you can still recover it with this solution.yes. if you have the first or last file corrupted, format the card. that's how much you can do. you still can use the video files that are not corrupted, and likely you won't have corrupted files again if you use the camera correctly.![]()
