- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
had you started the car after setting it up for this test?
I'm measuring the voltages in two places:where and how are you measuring the voltages?
Yes, but the hot side of a constant voltage fuse in the fuse box will be very close to the voltage that the camera is receiving. I just can't reach the metal part of the tap itself because of how it is oriented but I will look for a way to do it. Although, I'm fairly certain that the difference is not that much. Like I said, I'm already measuring 12.2V on the fuse box and 12.3V at the batt terminals. The cutoff voltage is 12.4V.You need to measure it where you have tapped it, voltage at the battery will be different
Yeah, I'm not worried about the values actually. What I'm trying to achieve here is to know if the cutoff voltage works or not. And what caused the battery drain in the first place. My gut tells me that the cutoff did not work and since my car stayed in the dealer for a couple of days without being driven daily for an hour or so (like I normally would), it got discharged.I think you are being too accurate, 0.1V is not very much and not something to worry about. Find out when it does turn off, currently we have no idea if the cut off is working at all, or if it is just 0.2V out from the value your multimeter is measuring, and maybe your Fluke is incorrectly calibrated - has it had it's annual calibration?
The good news is that if your battery still holds 12.3V after powering the camera all night, then the battery is in pretty good condition.
The professional Fluke meters can all be calibrated, and should be if you are working on something critical like aircraft.You got a good point about the calibration. No, I've had this for a couple of years now and it never experienced a re-calibration. I wasn't even aware that it needed and if it is capable of being calibrated. Are all Fluke meters calibratable?
For hobby use there is no point, they will normally stay plenty accurate enough, I was just making the point that your meter may not agree with the volt meter in the hardwire kit.
Also, I wouldn't be surprised if the hardwire kit has an offset so that after turning off the camera, and the battery voltage has then increased a bit due to the lower current draw, the battery measured at the battery terminals will then be at the set point. But maybe jokiin would have mentioned that if it was the case. To measure accurately how full a battery is, it should be left disconnected with no current draw for a few hours; in the car with the radio, clock, alarm, ECU (including OBD) systems all operating, the battery voltage will always be a bit fuller than the volt/%full tables show, so there is no need to worry about 0.1V.
If it was set to 12.4, and I left it recording overnight, then, keeping things simple, in the morning I would expect to find it no lower than 12.4, however I wouldn't worry about 12.3.If it is set to 12.4V and my voltmeter measures 12.0V and the camera still doesn't turn off, do you still account that for error tolerance?
How low it dropped overnight is of no concern, even if it reached 11.8V.
But, I feel that we are being asked to make a judgement without knowing the facts! Even the basic facts like does it ever turn off? Without knowing the facts you can't make a proper diagnosis, maybe something is stopping it turning off, like receiving a short pulse of 12.6V once per minute because of ECU activity which doesn't show up on your meter.
We don't know if it turns off or not, maybe they left the radio on overnight, or the boot light, or headlights on overnight!
How about you set it to 12.2 volts and then run it until it turns off, turn the head lights on if you want it to be a quick test, and if it really doesn't turn off then to avoid damaging the battery, I suggest terminating the test when you have measured less than 11.6 volts at the battery terminals for over 3 minutes, then recharge almost immediately. If it does turn off, then leave it for an hour and then measure the voltage at the battery terminals and compare that with the 12.2 volt set point.
You said "My gut tells me that the cutoff did not work".I'm not referring to what happened when my car is in the dealer. I'm referring to what I'm observing during my tests now. It doesn't turn off.
I don't consider that to be adequate evidence for us to work out what the issue is, or even to work out if there is any issue!
I'm a 100% sure that I got it wired correctly, that is yellow wire to ACC and red wire to BAT+. If you get them inverted, parking mode won't work anyway because the camera won't receive constant voltage when the engine is off and it won't signal the camers to go to parking mode (the only purpose of the ACC voltage).I have the same problem but inversed. I've 12.1v - 12.2v checked on fuse tap with 2 different multimeters with cutoff on 11.8v and it cuts power to the cam.
I'm not in the mood to disassemble the hardwire kit and test on adjustable power supply...
kevindd992002:
silly question: are you sure that yellow cable is connected to right fuse?
If the yellow cable is connected on a fuse that has constant power the cutoff not work.
I use that hack to prevent my cam turns off.
