Sorry guys, got you two mixed up in replies[emoji849][emoji849]!!
Devilment, I've been following various threads. I've got a 129 duo and the 3 wire hardwire kit, and was particularly interested in 'parking mode' but wanted the ability to easily switch parking mode on/off if I wanted to leave the vehicle unused for days in a safe location, hence the switch. I saw some info about people fitting switches but one problem seemed to be you had to switch the permanent 12v on everytime you started the car otherwise the camera would not kick in at all. I presume that's what you are trying to resolve with the addition of a diode and capacitor?
Sent from my SM-G950F using Tapatalk
Ah, no. Diode and capacitor was a thought I had about not letting the voltage drop to the A129 main camera when switching between the two modes. If the rocker switch is switched quick enough, the A129 may not even be aware of the switch-over in power. This will require testing to see if diode/cap are required.
Onto my thinking about using a DPDT (double pole/double throw) switch to resolve the issues others were having with a SPDT or SPST switch.
With the SPxx set-ups, the ACC wire to the HK3 unit was permanently powered. From their testing, the HK3 unit does not like to see power on the ACC wire before the 12V is powered and this seemed to confuse the parking mode detection. With my proposed solution, the ACC wire to the HK3 unit would only receive power if the switch is in position II and the ignition was on. The ACC source from the fusebox is doing double duty. In position I, it's powering the A129 unit; in position II, it's being used for its true purpose to send a signal to the A129 unit for parking mode activation.
Position O:
No power from any source to the A129 unit.
Position I:
Ignition off, no power to the A129 unit.
Ignition on, A129 is powered from an ACC source in the fuse box to the 12V into the HK3 unit.
Drive to the supermarket and park up.
Switch off ignition, power from ACC source goes away, A129 shuts itself down.
Basically, position I behaves like you were running from the 2-wire kit or cigarette lighter port.
Position II:
Ignition off, A129 is powered by permanent live.
Switch on ignition, A129 now senses power on the ACC line.
Switch off ignition, A129 detects lack of power on the ACC line and activates your desired parking mode.
Basically, position II should act as if the HK3 is wired normally and there was no physical switch in place.
