StrayCam
hmmmm....my understanding is to use "parking mode" you need an "always on" circuit and an "accessory circuit" that only gives power when the ignition is on. - - If you have a lighter socket that turns off when the ignition turns off, you would have no power. And if you have an "always on" lighter circuit, your cam will be always on... - - You will not have the safety of the cut-off switch in the 3-wire kit that you can set to different levels so you don't accidentally drain your battery. - Perhaps I'm wrong on these details....?
