D
Deleted member 56879
Guest
I had my A129 running flawlessly for about six months, then sometime in August 2019 I started noticing that the camera would have rec / mic light on, but when starting the car, the screen would not light up and change over from Parking Mode to Continuous Mode. Given the camera was under warranty, I reached out to BBMC and their service has been excellent and we're still working on resolve, but in the mean time I thought I'd post here to see if anyone else had similar experiences.
We did all the usual verifications and checks, new SSD card, format, reset settings, check wires... the camera would work as normal, both parking and continuous for about two days then lock up again. BBMC swapped the camera out.
When I got the new one, I upgraded from 1.5 to ver 1.9 and inserted the SSD card and setup the camera. Everything worked perfectly. After two days, I noticed the same symptoms, but with one additional note. After resetting the power, WiFi would be enabled. When checking the camera settings, all seemed to be set to default.
Again, I checked wires, different SSD, format, reset settings, etc... all worked good for two days, then locked up again. Upon logging into the camera the settings seem to stick except one, time settings. It switches from GMT 0 instead of being GMT -7.
Like I said, I've been working with BBMC, and they've been great and we'll figure something out, but in the mean-time I thought I'd check here to see if anyone has had similar situation.
Regards,
Regards,
