A129 Settings...
GazSuttonUK
Sutton Coldfield, UK
2 x Mini 0805
I have hard wired the camera, using the three wire hardwiring kit from Amazon...
Do these settings look ok?
Video Res - 1080P + 1080P
Time lapse Recording - Off
Loop Recording - 3 mins
Motion detection - Off
G - Sensor - Low Sensitivity
Bitrate - Low
Boot Delay - Off
Parking Mode - Off
Parking G - sensor - Medium Sensitivity
GPS - On
Screen Saver - 1 min
Frequency - 50 Hz
App version 2.9.1
Firmware A129:V1.9
Many thanks and Merry Christmas...
turkayguner
Istanbul
Turkey
Does G-Sensor work in parking mode? Did you test it after leaving your car lets say 30 mins or one hour later?
TheGhost31
Haute-Garonne
France
Hi, I'm a new user of this dashcam
I almost have the same settings like you but just two things.
Firstly, Parking g sensor with high value (but not sure its really working yet)
Secondly, On the road, g sensor to MEDIUM value, no false record with bumps on road for the moment. If you get some records not required, set it to LOW as you did.
Edit: bitrate is on High for better quality to record.
Display: 50hz is good for UK. 60hz is only for North America and some specific countries
Of course, you will have to set the state ON for the parking mode and not OFF as its seems to be with your conf. Otherwise, when you stop your engine, the camera will be cut after 5 seconds :)
And I don't know if it's important or not but, I connected using the USB port on the camera side, not gps mount :)
Gooffeyguy
St. Louis
Bitrate - Low
Parking Mode - Off
Frequency - 50 Hz
Try medium sensitivity for G-sensor while driving
Bitrate - high
Parking mode - either auto detect or low bitrate
Parking G-sensor high
Frequency depends on what country you are in and what frequency the AC electricity works at. North America is 60hz
Sent from my SM-G930V using Tapatalk
