OK, not had chance to set mine up yet but have a 64gb card, how long should i expect the recording to last for this card ?, also what would the best video settings be for quality and length of recording ?
Not sure on MAC.Thanks for the replies, one more question on the 64gb card, the instructions state that the card must be formatted in fat32 but i don't have a PC only a Mac, whats the best option for formatting it ?, think the card in in Exfat
No, 64GB cards format as exFAT in the camera but FAT32 is required for recording. I'm sure Google will have a better suggestion than replacing your Macintosh by a proper computerNot sure on MAC.
Check how it's formatted from the factory. It may already be in exfat.
If not, format in the camera. It should format properly.
That doesn't make sense for mfr to do that.No, 64GB cards format as exFAT in the camera but FAT32 is required for recording. I'm sure Google will have a better suggestion than replacing your Macintosh by a proper computer
The dashcam is supposed to format correctly in itself.
'I can format but I when I format it, I can't use it'. Bad idea.
Okay, that makes sense.it's because it's a firmware hack, it doesn't support the cards correctly, there's an updated SDK to do that but there's a licence fee involved so it can support large cards only if formatted by a 3rd party utility
I guess they have some app/software for MAC to format correctly in FAT32.
I do know about disc utility but just wanted to add true Fat32 as per the instructions.
EDIT: Made no difference - I formatted the 64GB cards in the dash cam using the 'Format' option but it made no difference, the 0806 still freezes after 7 or 8 seconds when recording in any resolution larger than 1920x1080.
You have 1440 available on that clip, I think the higher resolutions take longer to become available.I just got the cam and have it on the highest video settings and also updated the firmware to the latest. When i playback the video, the video looks sub par and not as sharp as some i've seen. Is it the mov file format? . Youtube only gives me 720p at highest res.See what i mean.
J | My Final Debrief On Gearbest | Mini 0806 | 4 | |
X | What is the mini0806 x44 on gearbest? | Mini 0806 | 2 | |
Buying from Gearbest | Mini 0806 | 8 | ||
M | Mini 0806 from Gearbest.com | Mini 0806 | 2 | |
K | Another Mini 0806 failure - Bought from Gearbest | Mini 0806 | 19 |
