M elementM-Element said:did you changed to a different password?
If so, maybe you can try reset it back to "blackvue" see if it work.
e30blitz said:No go
Still no luck
jazzyone said:By chance are you connected to the BV with another device while trying to connect with your iPhone, perhaps a tablet or a different phone?
The camera can only connect to one device at a time.
If not how strong and how stable is the BV wifi signal strength? You should have full, consistent signal strength at close distance. If your wifi signal is weak/unstable, you could have a problem with the Wifi-module on the camera and need a replacement.
Finally, you need to use the default password. If you changed the password through the iPhone APP, the password will not work.
EDIT: Actually, looking at your screen capture, it looks like you changed the default password to something else. You entered 13 characters. You probably changed the default password using the iPhone APP. In order to change the default password, you need to do it in the desktop application, not the iphone application. Changing the wifi password on the iPhone application will cause connection problems.
e30blitz said:Well I like it
BukVieng said:I have the same issue. But this was after I updated to the new Blackvue App. Previos iPhone App version I was able to login and view my files. Now it is doing the same as you. It is connected to the Blackvue because you can still see the Live feed and the settings...but no access to the files. I am also looking for an answer...
V
V
BlackVue Wi-Fi DR500GW-HD Cannot connect to WIFI | DR500GW-HD | 2 | ||
New firmware v1.011 from Blackvue DR500GW-HD WiFi | DR500GW-HD | 28 | ||
BlackVue Sport SC500 1080p / 60Fps / WiFi / 12Mpix Sony Exmor / | DR500GW-HD | 8 | ||
Z | Effective range wifi BlackVue DR500GW HD | DR500GW-HD | 3 | |
R | Wifi Blackvue DR500 To PC | DR500GW-HD | 3 |
