Alexsoll custom 1.004 installed and working great.
Something that might help others, when setting ap_11n=1 in the config.ini, if you then use the windows app to save a change, it clears this setting out.
Took me a while to figure out why I wasn't getting full link speed.
13Mbps bitrate is fine for me. I won't use 15Mbps. Even set my 650 to 13Mbps too.
Alexsoll can you tell me if the increased bitrates also increases the heat in the dashcam? BlackVue used to have heat issues with older models but lately there is no issue.
No issues either upgrading. Alexsoll's custom firmware has truly maximized the performance of the DR600GW. A different beast to the standard Blackvue firmware! Not sure if much more can be gained but as it stands it is now its a pleasure to use.
Did you PM alexsoll as directed in the instructions?
I saw you posted here but it needs to be a PM with your device, trans Id and amount.
After donation, access the automatically will not open!
Contact alexsoll indicating evidence of support ( the transaction number, amount and model DVR)
Within 24 hours after sending the message) access will be activated.
P.S.Messages in PM, without specifying the selected data will be IGNORED.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
