Hi everyone,
Let me introduce myself first, I am Agave from Istanbul and owner of 2021 BMW 3.20i (G20).
I want to write my problem and I hope that someone have a idea related to it. I have a dashcam which is viofo A129 Duo. I used it before on my 2018 F20 1.18i and there was no problem. However, I cannot use this camera in my G20. I made connection of it properly to fuse box and camera begin to work properly but the car’s front FPMS (Tire-pressure monitoring system) gave fail and the car couldn’t measure the tyre pressures. Also, RCDLR (remote control door lock receive) did not work properly. Normally, remote opens/closes the doors away from the car (lets say from 50 metres). However, when camera installed, remote began to work only near the car (~1 metre). If I disconnect the wires of the camera, FPMS and RCDLR return to working normal again as before installing the dashcam. Whenever camera opens, car’s FPMS and RCDLR does not work properly. Whenever I disconnect the daschcam, everything be ok.
By the way, I’ve tried the connect the dashcam not only by fuse box but also via usb cable. The problems began again. The problem is not related to connection method, the problem is camera itself.
I think that maybe the frequency of dashcam’s wifi and the car’s frequency effect each other negatively. Then, I’ve checked whether the wifi is on or off and I’ve seen that the wifi is off already.
My last idea related this issue is that, GPS of dashcam and GPS of car may be effect each other negatively.
Meanwhile, I’ve done research related this issue and the only topic I could find is below. (The same problem has been discussed in the Camaro forum, but no solution has been found and the issue is left in the air.)
https://www.camaro6.com/forums/showthread.php?t=451390
As of today, unfortunately, I can not use my camera. If anyone can help me, I will be grateful to them.
Thanks a lot from now.
