HonestReview
- Feb 9, 2019
- Sweden
@HonestReview, you failed to mention that your first A129 Duo needed to be replaced and you initially complained about issues with your second one. How long have you had the A129 Duo that you are now designating it as reliable? Most every product I own that costs what the A129 Duo costs or the A139 costs go for years trouble free. With dash cams concluding that a camera is "reliable" after only months is not realistic. You are also waiting for your A139 replacement too, no?
Raid hard drives are a different breed of cat. Backing up massive amounts of data because equipment might fail "at some point" is not the same as having a primary product that is well known for often failing right out of the starting gate or shortly thereafter. Memory cards are a separate issue from dash cam hardware, just as hard drives and raid hard drives are essentially a separate issue from the computers themselves. You are redundantly backing up data, not running a duplicate computer. A closer analogy might be simultaneously running two computers side by side because you fear that one of them will crash or go up in smoke at any moment.
Is English not your first language! I answered the ownership length of my A129 NUMEROUS TIMES> Two, Dos, två.....Do I need to write this more clear in some other language for you to comprehend? Both Replacement and the 2nd Camera I purchased have been owned and running over 2 years......PROBLEM FREE. Minus the Dupe Frame Bug. Cameras have never Froze, Lost Video, etc.
I've had COUNTLESS memory cards fail. One taking with my trip photos which I neglected to back up. And NUMEROUS Thumb Drives.
The point, which you again don't grasp, is that solely relying upon one item where you're placing an upmost importance, is a recipe for failure. Just as Memory Cards, Thumb Drives, and Hard Drives Die (which can take with it CRITICAL FILES), having a backup is key.
One Dash Cam is Great. If it fails and you need an accident / event video, you're screwed. Two Dash Cameras (redundancy), gives greater reassurances that at least one works.
.....Can lead a horse to water...Can't make it drink....
FYI: Did I mention the A139 being reliable? No... Stop putting words in my mouth. I can't say YES or NO until I get a replacement. Mass Production does lead to failures. Doesn't mean these failures result in a "Bad Product". Especially if a Replacement works just fine. I.E. my A129 Duo for last 2 years.
