You can edit the file in the Viofo app select the start and finish time do a test play then save it to your phone.
I did a test on a 1min video on my iPhone 8 and it took about 5 mins from start to finish.
Thank you for this, and the video below it!
After saving the (1 minute) edit does the original remain intact?
Happy to share, thanks for saying that!
The original file is not affected.
It saves a new file of the edit.
I've learned that Dashcam Viewer really does not play nice with Viofo A129 Plus Duo. I posted a prior question here about Dashcam Viewer not correlating the front and rear cameras. Today's issue is the result of my camera capturing an accident in a Walmart lot where a driver backing the the wrong way down a parking lot row backed into another car. I showed the cop the clip from the dashcam, I wanted to send the relevent section from the file. Smaller and not a bunch of time lading up to the incident. The file plays fine, but when I try to export, and enter the start and stop time DV says "Movie Duration: -1 seconds". I purchased a license to do some of the cool stuff this is supposed to do. Have yet to do anything useful with DV.
BTW, a backup for those running into issues like these is OBS. At least I can get a section of the files without fighting bugs.
Hi BobW: Hard to diagnose the issue with just a single image, but one possibility is that you have a non-ascii character in the path to your videos. The reason is DCV relies on a helper program called ffmpeg.exe, which needs ascii-only characters in video file paths. I can see that ffmpeg is having trouble finding your video because normally the video resolution would be reported in the bottom left, instead of "0x0". The duration of -1 seconds is also a giveaway (I cover this in the FAQ). Try moving the video to a directory whose path doesn’t include any unicode characters. Usually, drag/dropping the videos directly from the SD card onto Dashcam Viewer works.
This problem occurred using the card directly from the dashcam. Unless it's writing unicode characters to the card - which was formatted in the camera - I don't see that being the issue. The full path for the video when I copied it to my PC after it gave the -1 seconds directly from the card is C:\Users\Bob\Videos The file name is 20250914171951_000183F.MP4 I dropped another copy in the normal windows 10 created downloads folder, and it does the same.
So, some more playing. I changed the name of the file. I deleted the "0" after the underscore. Opened it with DCV. Clicked mov export. then it shows a length. Ok. Figured maybe the camera wrote some invisible un-liked character and editing the name cleared it. Nope. edited the name again and added the "0" back. Once again, -1 length. It's as if DCV doesn't like that file name or length. This was done in Desktop\DCV Test. This might also be the cause of the prior issue that I had which was never resolved where DCV didn't correlate front and back videos. If you've got some way of me getting you the file - I can send a OneDrive link - you can try it directly.
View attachment 86006View attachment 86008
I have DCV Pro. If you would like to post the video to a Google Drive, you can DM me the link, and I will test the import on my Mac Studio. Apparently, you are using Windows, but it will be interesting to see if the MAC will have an issue with the file.
I have an A129 Pro Duo. I just ran three videos through DCV and had zero issues.
BobW, the filename dependency is an interesting finding and valuable clue. Yes, please send me a OneDrive link to a sample raw video from your dashcam (or use https://wetransfer.com). If you don't have my email address, DM me. I'll see if I can repeat the problem on Windows and Mac versions of DCV.
As an aside, I quickly learned that there is no standard in the dashcam industry for embedding meta data (like GPS or G-Force) in a file, nor is there a standard method of video file-naming. In fact, even within a single dashcam model of a single manufacturer, there can be multiple formats of file-naming (caused by f/w updates). Lol, makes my head spin. 🫨
It'll be software developers having a bit of fun when it comes to file naming 😀
@traveler
Could you please review the playback of the files that play in succession?
I’ve noticed there’s about a 10-second gap between each video, which becomes quite distracting when viewing them continuously.
here is a quick example.
@LateralNW I played your YT video but I don't see anything wrong. The 2nd video seemed to play right after the first with only a short pause (less than 1 second). Perhaps I am missing something?
@traveler LOL google blocks me from watching this video from DCT is wants me to login thinks I'm a bot!
My apologies my fault. It may have been my computer as I had to basically rebuild it yesterday after a couple of days/weeks of performance issues.
Also it may have been that I think I was running the program and had it pulling video straight from either the dashcam or from the memory card.
So the delay which isn't shown on that YT video was from I guess pulling the files from an external device. I think frustration may have got to me that day just in general not your program.
I'll remove the YT video and delete my request. Sorry.
No problemo! 🙂
Dashcam Viewer v4.0.8 Released
Dashcam Viewer
v4.0.8 was released today for both Mac and Windows. This is a minor update to support the Garmin Dash Cam X310. Version 4.x is a free update for all Dashcam Viewer users.
New Camera Supports:
  • Added support for Garmin Dash Cam X310
Dashcam Viewer v4.0.8 showing Garmin Dash Cam X310 video and data
Dashcam Viewer and Dashcam Viewer PRO are PC/Mac applications that allow you to play your dashcam's videos while simultaneously viewing your vehicle's location on a map. There are many other features in the software which are detailed on our website (https://dashcamviewer.com). The free version is fully-functional and allows the loading of up to 2 videos at a time.
Hello John,
Many thanks for keeping the updates going.
Very much appreciated.
Hope you & yours have a safe & Happy New year along with every one else on this fora.
2aw7w7rp
Thx, now found ;-)
Two days ago I send John from Dashcamviewer the Zip from my Dashcam via Wetransfer (as suggested), also a mail with short infos / details.
But till now the uploaded file is not downloaded, and will be deleted in 1 day automatically :-(
Update:
John contacted me and he informed me, that it seems the camera not store the GPS informations in the video files (there also no extra file).
GPS data is only available in the video "hard coded".
