Ddpai m6 plus
Just uncompressed the e-dog tar.gz, it seems it's only uncompressed as is in the SD card, it contains audio messages in .pcm files (that can be opened as raw 11Khz 16 bit mono files in Audacity). The audio is in Chinese (of course) but I don't know if the geodata is for china only, as I don't know the format used in the tt160518.dat and tt160518.idx files. The enterprising hacker could replace the audio files by any other language, but without the database format, it's useless.
I guess I will disable e-dog for the time being.
In the process of decompiling the latest update :
# binwalk rootfs hibernate uImage uboot
Scan Time: 2016-08-19 21:51:14
Signatures: 212
Target File: rootfs
MD5 Checksum: c5e67d89ae106a63d4685de81fd2c43e
DECIMAL HEX DESCRIPTION
0 0x0 JFFS2 filesystem, little endian
3368273 0x336551 ELF 32-bit LSB
3370876 0x336F7C JFFS2 filesystem, little endian
5511836 0x541A9C TIFF image data, big-endian
5512328 0x541C88 JFFS2 filesystem, little endian
6655813 0x658F45 ELF 32-bit LSB
6657668 0x659684 JFFS2 filesystem, little endian
6673813 0x65D595 ELF 32-bit LSB
6676504 0x65E018 JFFS2 filesystem, little endian
7370309 0x707645 ELF 32-bit LSB relocatable,
7372916 0x708074 JFFS2 filesystem, little endian
7387937 0x70BB21 ELF
7388468 0x70BD34 JFFS2 filesystem, little endian
7389621 0x70C1B5 ELF 32-bit LSB relocatable,
7392972 0x70CECC JFFS2 filesystem, little endian
7814573 0x773DAD ELF 32-bit LSB
7817244 0x77481C JFFS2 filesystem, little endian
7861361 0x77F471 Copyright string: " (C) 2006 Free Software Foundation, Inc.ion, Inc."
7862272 0x77F800 JFFS2 filesystem, little endian
Scan Time: 2016-08-19 21:51:45
Signatures: 212
Target File: hibernate
MD5 Checksum: 2eed24ad027aa0024e122acb2f9c39a9
2070297 0x1F9719 Private key in DER format (PKCS#8),
3177563 0x307C5B mcrypt 2.5 encrypted data, algorithm: "p", keysize: 2140 bytes, mode: ""|%l",
3614263 0x372637 ELF
3679973 0x3826E5 U-Boot boot loader reference
3821626 0x3A503A POSIX tar archive (GNU)
4921149 0x4B173D mcrypt 2.2 encrypted data, algorithm: blowfish-448, mode: CBC, keymode: SHA-1 hash
5178344 0x4F03E8 TIFF image data, big-endian
Scan Time: 2016-08-19 21:52:05
Signatures: 212
Target File: uImage
MD5 Checksum: 194ff53e2d1fd87c72f1df18aebe906d
0 0x0 uImage header, header size: 64 bytes, header CRC: 0xDF503D84, created: Wed Aug 17 11:10:01 2016, image size: 2994088 bytes, Data Address: 0x80008000, Entry Point: 0x80008000, data CRC: 0x465E6978, OS: Linux, CPU: ARM, image type: OS Kernel Image, compression type: none, image name: "Linux-3.4.35"
18068 0x4694 gzip compressed data, from Unix, NULL date: Thu Jan 1 00:00:00 1970, max compression
Scan Time: 2016-08-19 21:52:10
Signatures: 212
Target File: uboot
MD5 Checksum: cd51f9a35a1b6d9e14a93af4a19e7fdf
200104 0x30DA8 U-Boot boot loader reference
201055 0x3115F LZO compressed data
223773 0x36A1D U-Boot boot loader reference
the geo data will only be for China
I know the DDPai M6+ has a smartphone app, but for those of you who like to view the videos and GPS data on your Mac or Windows PC, I've added DDPai M6+ support to Dashcam Viewer v2.1.8.
Dashcam Viewer v2.1.9 was released today to address a bug in reading the DDPai M6+ GPS files. It will make Dashcam Viewer look for both ".gpx" and "_D.gpx" files in the "103gps" directory. Apparently the DDPai M6+ sometimes sticks _D in the gpx filenames. Not sure why since I don't own this dashcam nor do I have it's user's manual. Apparently there is a .git directory in the 103gps directory as well but I am ignoring files in there. I am not sure how the .git files figure into the movie list in the "100video" directory. Anyway, if there are still issues loading the gpx files let me know.
Note: only the Windows version of DV is compatible with the DDPai M6+ MP4 movie format.
- John
Website: http://dashcamviewer.com
Facebook: https://www.facebook.com/dashcamviewer
Excellent, THANK YOU !
The .git file is in fact a tar archive.
I've had my m6 plus for a couple of week now. When I first got it I had an iPhone 4 and the tracking maps worked fine and when I took a photo it said at the top of the photo where it was taken. I've now got a Samsung s7 and have reinstalled the app and Now it just shows a blue background on the tracks. It gives a distance etc and the line of the route travelled but you can't actually see where you traveled as it's as if Google maps isn't working on the tracks. If you connect to the camera it will show you your current position on the dashboard. It also gives no info on the photos. Any ideas where Im going wrong?
I have the same issue. Techmoan had an iOS device that showed the correct map behind the GPS path - presumably constructed from the GPS files.
If you can see the latitude and longitude of the location shown on the map, you will find that it is on the same latitude line but the longitude is assumed to be west of the prime meridian.
Greenwich which is 0° - any point west of this line has a negative longitude value, any point East of this line has a positive value.
In my case, I appear in Norfolk when I am in Nottingham. The same latitude, but with the value of the longitude treated as + when it should be -.
If anyone has a format / class structure of the GPS file, then I expect it has the correct values recorded and it is the android app (which appears to be very buggy) that needs updating.
I am emailing the app developers and will leave same comment on the play store.
Hope this makes sense and helps.
Just seen this on their fb page. I figure this is the issue were having?
Latest firmware update also made the GPS logging better (for the most part) :
- no more uneeded spaces before the custom waypoint message
- $GPGGA in addition to the $GPRMC messages
- new $GPSENDTIME message at the end of the log files
@Pixel K., are the files still not compliant with the standard? Or are they working on fixing that?
That's good news. The GPGGA message means the dashcam is recording additional parameters. These include Altitude, HDOP (GPS positional accuracy), and Number of Sats In View. Dashcam Viewer recognizes the GPGGA tag so if this tag is present additional graphs and widgets will appear, like so:
In the above displays, notice the drop in GPS number-of-satellites-in-view and positional accuracy when going under the overpass (this was from a BlackVue dashcam).
Being a data geek, I like it when the manufacturers add these extra metrics. 🙂 Only a handful do.
John
So i bought this camera and have been using it for a couple of weeks now. It is my first dash cam and i went for it on the back on the review from Techmoan.
So far it seems to be working fine however for some reason the video seems to be "inverted?" I'm sure when i first used it the video was the right way round, but now it's not. Just to be clear, if i sit in the car looking out the windscreen from my driveway, the car that is parked on the road out front is to my right. On the live video feed and the video itself the parked car is on the left... This may well be a newbie thing (yes, me), but doesn't seem right. Any ideas what i may have done wrong?
Mavrik
The gps log still contains bad formatted message, but at least they are usable by most programs now. They still are named .gpx, but aren't gpx files, just NMEA logs, at least it's a move in the right direction.
...So far it seems to be working fine however for some reason the video seems to be "inverted?" ...
The camera (or mount) has an orientation sensor for sure, The first video taken upside down on my desk (with the mount down) went the good side up. All the other videos in my car (with the camera upside down, mount glued on the windscreen) are also the right side up.
And I have no horizontal inversion in the car either (didn't check on the desk, sorry).
Mavrik
Mavrik
Under camera settings there is an option left/right orientation. It's enabled by default. Turn it off.
Hello,
I'd like to know how to get the DDPai M6 Plus to turn off after its been parked. Is there a way to accomplish this in the camera's settings? I'm not interested in the camera's park-mode/time lapse capabilities because I don't want to buy a separate battery. Right now I have the camera connected to the cigarette lighter fuse port which is powered all the time and I'd like to keep it that way if possible.
Thank you
