speedingcheetah
- Nov 15, 2016
- Twin Cities, MN
- VIOFO A119 Mini2 (Front & Rear) [A119v1/Mini 0826 old cams]
I have noticed some excessive flickering with the built in LCD when it is plugged into my vehicle. It doesn't do it when I connect the cam up inside home. (Flicker option in the settings has no effect). The recorded videos are just fine.
Unless this is just a normal thing when its sunny out, I suspect its a power issue. I do have it on a much longer cable in the car, since I have to wire it under dash and around door frame up to top window to hide the cable. It is plugged into the 12v cig adapter plug that it came with. I have also tried to direct plug the into my 3 amp powered usb port i use for my phone...no change.
I have a Mini 0826 cam with a total of about a 15ft run of cable to the rear....it powers fine no matter where i plug it.
I had originally tried a USB Y splitter cable off the one usb cable I already had run so that I could power both the front cam (A119) and my rear cam(Mini 0826) off of the one 3a port. The A119 most certainly had power issues then, as it would turn on and record for a few secs, then power cycle. Massive lcd flickering and even rec light was very dim. The Mini 0826 ran fine. I removed the splitter cable and ran a dedicated cable for the A119.
Anyone know the power requirements of this A119 cam? I have a usb volt/amp meter I am gonna hook up and see what its pulling.
