Git2 - Start/Stop button - No longer working
Richard Lynch
Ireland
Hi Folks,
Hope you can help.
Was using my Git 2 today in waterproof case. All was working perfectly.
Then the shutter start/stop recording button stoped working.
I am now unable to start or stop a recording or take pics.
Pressing for long or short periods does nothing
Is there a fault ? hardware issue?
Richie
@gitup
@GitupII
gitup
China
GIT1, GIT2
@GitupII is a user, not from GitUp company.
I have replied your PM.
R
Richard Lynch
Ireland
Hi Gitup
I tried to update the firm ware a few moment ago.
However as the Start/Stop button is not working i am not able to select the Mass storage menu option
because of this i am not able to apply the firmware
Please advise and provide a solution
i would like to use the camera this weekend
@gitu
thanks
Richie
Nigel
Devon
Gitup F1, A129, B1W, B2W
You can put the firmware on the memory card using a card reader, then put the card in the camera and turn the camera on, wait 40 seconds and that is enough to update the firmware.
R
Richard Lynch
Ireland
@Nigel
@gitup
Thanks Nigel, i have updated the firmware as per your instruction. the update appears to be successful as the red led flashed quickly serveral times.
However post update the stop/start button is still not working. the firware update has not resolved this.
Got further advice
Is it hard ware issue
thanks
Richie
Nigel
Devon
Does the button still make a nice click when you press it or does it feel like it is stuck?
R
Richard Lynch
Ireland
Hi Nigel
The button feels normal.
It clicks on press down and again on the way back up.
The button appears to be free moving and not stuck.
@Nigel
Richie
Nigel
Devon
Probably best to wait for more advice from gitup then...
Gibson99
Houston, we've had a problem, Texas
Yes
You might try opening the camera and looking to see if maybe the ribbon cable for the button/LED is loose or damaged. Can't hurt to reseat the cable in its connector.
gitup
China
GIT1, GIT2
Dinkydao
Finland
Same problem here. Shutter button stopped working.
obilgic
Turkey
gitup git2
after dropping my git2 cam from 1 meter high shutter button does not working. any suggestions would be appreciated.
aleZ
Germany
Hi Gitup,
I sent you a PM on Jan 28 regarding exactly the same issue with my camera.
What shall I do?
D
Deleted member 24437
Guest
A small accessory I.C.soldered at three points to main PCB has the shutter button!
obilgic
Turkey
gitup git2
Open it and take a look at the parts. Maybe the little PCB underneath the button broke away from the main PCB.
A further remote diagnosis is impossible.
i opened the cam and you both right. 2 out of 3 soldered joints is broken.thanks for your help.
now where can i found good soldering video to apply to this tiny piece?
drygdryg
Germany
Insert the parts back into place (into the housing) without closing the lid. Then they are in the perfect position for soldering them together. For soldering these three spots you won't need much soldering skills.
Anton Claeys
Belgium
I also had this issue and solved it by resoldering the button on the pcb.
This is caused by bad design because part of the plastic button-top pushes on the solder joints when it is pressed.
