From my observations, camera has software stabilisation based on data from gyro inside. It's obvious because when you turn off gyro stabilisation video gets even more viewing angle and a bit more resolution. So with gyro on videos have only near 1080p resolution.. so stabilisation is made by software which makes crop from sensor and moves it based on gyro data to maintain fluid move and get rid of shakes...
I bought this item http://m.aliexpress.com/item/323620...ero-3-3-4&tracelog=wwwdetail2mobilesitedetailWhere did you get this cable from?
but the seller wrong the item and sent this
I see that your mic is stereo but I only hear right channel. I think that the adapter is not doing it's job properly.This afternoon I tested a external microphone. It cost only 2€ and work very good.
Audio sensitivity in cam: Low
Some pics and video:
I have the same adapter and it really works just for one channel. And another one from GearBest (with straight micro-USB connector) also have just two wires in cable (instead of 3 required for stereo). So if you want stereo now you can buy expensive GoPro adapter or you can make adapter yourself.I see that your mic is stereo but I only hear right channel. I think that the adapter is not doing it's job properly.
GearBest's adapter has 10-pin connector but wire for just one channel :-(For stereo, need 10pin connectors.
Yes. Buying only original gopro or you can make adapter yourself.GearBest's adapter has 10-pin connector but wire for just one channel :-(
Yes I'm also ordered connectors from eBay. So I hope some day I'll receive them and I'll make stereo adapterYes. Buying only original gopro or you can make adapter yourself.
I bought this, and all is well.))
Yes, the adapter is mono. I knew but I want test the position of microphoneI see that your mic is stereo but I only hear right channel. I think that the adapter is not doing it's job properly.
December is not the latest firmware. Check the firmware thread in this forum and make sure you follow the upgrade instructions exactly. It's not the same as previous upgrades.Hi,
I tested every combination of resolution/fps (gyro on and all other settings on "default").
1080p@60fps: https://mega.nz/#!ek8zGKKJ!_Uje1y3MK0Wpx5H9t1MDmDuoctoWdUwioQO0_CdfKA8
1080p@30fps: https://mega.nz/#!qltCAIjZ!btBW3ooirF1I9q6gBXsY-ztaK5TWLzxT2cmixbDl5Y8
720p@120fps: https://mega.nz/#!ux9kDIKB!WjyeEny4nrR4LsQJceQpue6W1WdtK1KxjekhcdlM4pM
720p@60fps: https://mega.nz/#!LgsRlbKL!qkBnMdBMeGjUc21JIOsYict8wW0KfFmItmP4L8VCISc
720p@30fps: https://mega.nz/#!P1lXmDBZ!vDIzuh_cjWgXFlwev1DczbYaHWXpylcKIrhaPmYMQ74
854x480p@30fps: https://mega.nz/#!Ll9nUQjQ!6j2yz_N83xU66PbYhOaReAi66PuarijwpdPSk9ubzc0
640x480p@240fps: https://mega.nz/#!KltBXRDY!PznDTIKWEHUg5BWtjLLXbTPFnEyHkdhVmb8hZf_RVl8
As you can see, I have problems with 720p (all fps) and 640x480p@240fps.
Firmware is the last from December.
