If you connect it with wall charger, please ensure the input is 5V 1A, and set the auto power off to off.may i know how the charging working? any light indication to know it is fully charged?
On the git1, the front led will be on solid green (not flashing) when the battery is full. I assume the git2 is the same. This is with the camera connected to a regular wall charger, not a computer.may i know how the charging working? any light indication to know it is fully charged?
First check to see if you have the latest firmware, as available on gitup.com, I'm guessing you haven't...Are there any settings I should optimize for lower-light situations? Gyro off etc?
The gyro does make a huge difference! Especially when chasing a toddler all over!
Yes , you are rigth, I take the preorder around the 23-25 october at full price, then after they drop the price . We are the one that take the risk when we order the first batch and for the next batch , they drop the price. I m still waiting for it and I don t know if I will get trouble with the focus when my camera will show up.
Plan to implement the FOV option for photo in next firmware.I do have a question for the experienced users of the Git series. I know I can switch the FOV in Video mode to Narrow or Wide. But how can I do something similar in Photo mode? Switching between 4:3 and 16:9 didn't seem to have a huge effect. Of course, I am still learning to use this cam.
I noticed that, will check further tomorrow.while playing with my camera today and i found this the screw was exerting too much force to the cover.
http://s28.postimg.org/vhsqu4lxn/IMG_7163_1.jpg
http://s11.postimg.org/o02jhwhi9/IMG_7165_1.jpg
Normally there is no waterproof problem, we test every piece before shipping.
Each one will take 4 to 5 mins to test the waterproof feature.
If you use the camera with our waterproof in correct way and got water in the camera, we will replace to you.
Normally action camera manufacturers will not repair the camera which damaged in the water as the PCB board damaged.
Please check the english manual here: git2 manual.Gitup, is there a link to your English manual anywhere? Mine came with Chinese and I'm not uhm very good at reading technical stuff in Chinese.
Also, is there a way to enable the settings currently used to appear in the video/photo like I've seen with SJCAM? It would show like Gyro: On etc.
Anyway to enable these at all? So I can see how each setting affects stuff in different environments etc.
Thanks!
her is the english versionGitup, is there a link to your English manual anywhere? Mine came with Chinese and I'm not uhm very good at reading technical stuff in Chinese.
Thanks!
Some icons will be showed on LCD screen like audio mute, Gyro, etc.
After enable the Gyro, you can see the "palm" icon on the bottom.
Remind us to introduce what's the meaning about the icon.
I see you mentioned this, is there a way to enable the settings currently used to appear in the video/photo like I've seen with SJCAM?Thanks Gitup and aim120 for the manual link! Actually, I meant to show them in the video or photo! Not the screen! I don't suppose this is possible yet?
