Auto WB works fine, Shutter speed and ISO can be changed but you can get flicker effect if shooting in artificial light conditions. Setting Metering to center works in most cases.Regarding white balance, shutter speed, ISO, slow motion and metering settings, what are your suggestion?
I recorded a lot of basketball games with Git2. So, I recommend using: 1296p 30fps, High bitrate, Gyro on, WDR on, Sharpness low, Narrow FOV. Then resize video to 1080p with dynamic noise reduction in post-process. You will get neat and crisp stabilized FullHD.
Anyone know where I can find this adaptor in metal? Only found in plastic...
VirtualDub it's freeware.what video editor are you using to produce your suggested settings?
One Photo every second, directly in the movie modePlease share your settings and post-processing for your air travel video.
The 72 degree(HFOV) lens is also for sale, and still improving the quality for that, a new version maybe released after 1 month.Dammm Gitup they make it damm hard for me to control my shopaholic tendencieslucky for me my wallet do a good job in stopping me pulling the trigger.
Is the 72Deg lens allso for sale by itself ?
For using the case with external MIC, we suggest using the GoPro Skeleton case which already have the port opened on side.Hi
I'm one of the new owners of this awesome action cam, but I ran into some problems. I use the camera for my MTB rides and I always mount it in the waterproof case, but the audio is almost nonexistent. I also bought a Gopro waterproof case for backup and I thought to drill a hole for the microphone, but unfortunately the case doesn't fit perfectly the camera, the side button being continuously pressed and keeps activating the WiFi connection. Is there anything I can do other than cutting around the side button and leaving a hole?
Another problem is that I cannot figure it out how to keep the camera from jiggling when mounted on my chest mount. When mounted normally, it stays as it should, but the angle is useless so I have to mount it upside down using two extenders. And so the jiggling begins. What is the best method to mount it properly?
Also, do you know any software to rotate the video and save it fast, without having to convert it in a new format/compression? Like preserving the codec, but only the video rotated. Right now I'm using Adobe Premiere, but converting 2-3 hours of raw footage is taking way too much time.
Thanx! Now the picture is pretty close to "flat" with saturation set to normal, wdr on and low contrast.6. Added: Contrast option for video and photo: Normal, High, Low
I found that indoors with the new 1/48 shutter speed it is good. I think for outside you need a ND filter to get 24fps looking reasonable. There is a good reason you don't see many panning shots on TV!Fixed: 2160P 24fps video not smooth, not perfect but much better than it was, it is now usable as long as the camera is still or you move very slowly while holding it. well done
