Me 3. GitUp could sell it as replacement itemMe too
Enviado do meu LG-E975 através de Tapatalk
#2 may be no when using a Git2 with a long lens. The 4.35 lens will not fit in the Gitup waterproof case.i don't know about #1, but i can answer #2 - yes, any case for gopro 3 or 4 will fit the git1 and git2.
@gitup will have to answer the rest.
Quite a nice effect 🙂Any idea what that could be...maybe a component near the CCD that becomes to hot? Or anyone having the same issue?
Regards
the-force
The Mobius has a more sensitive sensor, but a lot less resolution. In dark conditions like under trees the Mobius will have a faster shutter speed and thus have less motion blur. Your problem will be not enough light for the sensor, the only real solution is to get more light.Hello everyone!
It's already been a while with my Git2 and the experience has been a little bit sweet and sour.
I have recorded very good videos for some purposes but I don't get the camera to record as good as I would want for it's main application, airsoft recording.
Recording in the woods or places with a lot of... "textures"¿? everything seems to blurr . Leaves, branches, etc seem poor defined.
Why this happens? Is there any good setting configuration for this case.
I have a mobius as a self cam with the only setting changed to wdr and this doesn't happen. In fact, sometimes I get the impression the mobius quality is better.
Thanks for your help!
The Git2 is always best in bright sunlight, under the trees a Git1 would do a lot better since that has a more sensitive sensor than the Mobius although it doesn't have gyro stabilisation, or for what you are doing a Git3 might be good.
Neither, see Gitup's post: https://dashcamtalk.com/forum/posts/261396/Is there really a Git3 available, or is this a joke?
I think it is reasonable to assume that Gitup knows it's features and physical dimensions! And when he wrote "If you like such camera and prefer low light performance, you just need wait Git3." in response to a post containing "it would fit just nice on my rifle scope", you should be able to see why I connect that post with the post above talking about low light performance under trees and "airsoft"?So, why do some people talk like if its features and physical dimensions were known?
It called my attention too...
not available yet, but it's in the works. @gitup drops hints here and there about what it will be but there's no time frame just yet.Is there really a Git3 available, or is this a joke?
No, way to early for that.I was looking at the Yi 2, but it hasn't external mic support and i need it.
Can somebody throw an estimated release date for the Git3? more or less.
Gitup did post a timescale, but that was posted over a month ago on another forum so I won't quote it, these things do tend to change and depend on people like Novatek releasing components/SDK features. It suggested sometime before autumn.No, way to early for that.
Yes, we are working on Git3, even Git4, but maybe we will not call it git3 or git4 while release.I was looking at the Yi 2, but it hasn't external mic support and i need it.
