tom said:I found a Russian site with a link to the newer firmware (v1.9). I HAVE NOT TRIED THIS. If you have a bricked GS8000 with ambarella chipset, or like living dangerously, this may be a good updated firmware for you.
http://files.mail.ru/598E6B5D03DE42D89B507909AEBD82A8
kengu said:It seems it cannot stand the heat as after the cam was on in a stationary warm vehicle the screen did show some horizontal lines and the osd freeze. I let it run out of battery as I had no "reset button" at hand.
jokiin said:If its overheating it won't be a firmware fix, it will be a hardware problem I would think
Zaxela said:jokiin said:If its overheating it won't be a firmware fix, it will be a hardware problem I would think
I ordered 1 from foxoffer and second from geekbuying. They both have problem with overheating and freeze. I think everybody who bought this dvr will feel this problem with overheating. It is already summer in our country. When summer reach every country and everybody problems with overheating will begin.
Have you set up a "Screen turn off delay" function? My GS9000 also gets hot after a while, but if I set up that option, screen turns off after a while and after this DVR is only warm, not hot. maybe this will help you?Zaxela said:So how to resolve this problem with overheating?
ShPioN said:Have you set up a "Screen turn off delay" function? My GS9000 also gets hot after a while, but if I set up that option, screen turns off after a while and after this DVR is only warm, not hot. maybe this will help you?Zaxela said:So how to resolve this problem with overheating?
Marcus said:I have figured out (99%) anyway why our GS8000's are failing.
It is the battery packs, cheap nasty things, the constant charging cycle causes the battery to overheat and then overheat the circuit board which it sits directly against.
Marcus said:Pennies in the real world no doubt.
