Petesimon
Hey Bond hehe π I'm not sure, but if your camera partially works when flashing Allwinner firmwares, then likely your camera has Allwinner chip and some other sensor. So it may not be or have Ambarella chip. Those are usually for high end stuff like Xiaomi Yi and real GoPro. Too bad. We could use a good chip that runs Linux/Android in a camera for $50. π By the way, if you can discover which LCD (model/driver/whatnot) your camera uses by searching online, or extract and convert to fex (text) the script.bin from your own original firmware full_img.fex backup (if you still have it or can make it), then get the "lcd_driver_name" in the script.fex file and then try to get or build the right firmware file combo based on your previous experiments and based on this lcd info. Here is full_img.fex and 0 thru 6 little img files backup of my yellow cam. This is lcd info from the F60B firmware:Hey Pete I actually have the same as that backup I was hoping I had something newer or different but nope. My dash cam is ambrella if I spelled that right
Code:
[lcd0_para]
lcd_used = 1
lcd_driver_name = "ili9341"
lcd_if = 1
lcd_x = 240
lcd_y = 320
lcd_width = 108
lcd_height = 64
lcd_dclk_freq = 16
lcd_pwm_used = 1
lcd_pwm_ch = 0
lcd_pwm_freq = 50000
lcd_pwm_pol = 1
lcd_pwm_max_limit = 255
lcd_hbp = 60
lcd_ht = 405
lcd_hspw = 30
lcd_vbp = 340
lcd_vt = 670
lcd_vspw = 2
lcd_frm = 1
lcd_hv_clk_phase = 0
lcd_hv_sync_polarity = 0
lcd_gamma_en = 0
lcd_bright_curve_en = 1
lcd_cmap_en = 0
lcd_cpu_mode = 1
lcd_cpu_te = 1
lcd_cpu_if = 14
lcd_hv_if = 0
lcd_hv_srgb_seq = 0
lcd_rb_swap = 1
lcdgamma4iep = 22
lcd_bl_en = port:PB13<1><0><2><1>
lcd_power = port:PB12<1><0><2><0>
lcd_gpio_0 = port:PC4<1><0><2><1>
lcdd3 = port:PD1<2><0><2><default>
lcdd4 = port:PD2<2><0><2><default>
lcdd5 = port:PD3<2><0><2><default>
lcdd6 = port:PD4<2><0><2><default>
lcdd7 = port:PD5<2><0><2><default>
lcdd10 = port:PD6<2><0><2><default>
lcdd11 = port:PD7<2><0><2><default>
lcdd12 = port:PD8<2><0><2><default>
lcdclk = port:PD18<2><0><3><default>
lcdde = port:PD19<2><0><3><default>
lcdhsync = port:PD20<2><0><3><default>
lcdvsync = port:PD21<2><0><3><default>
and if you're feeling adventurous, users nutsey and thegamut lead me to Russian language forums about these cameras. I took Russian class last year so I can read cyrillic and I remember a few words... Also, I think those users are good in Russian. but I haven't yet found anything so useful there compared to here (and goprawn). still looking. mostly just for fun hehe.
http://4pda.ru/forum/index.php?showtopic=706191
http://4pda.ru/forum/index.php?showtopic=759392
cheers.
