Hardwiring the A119S
Discussion in 'A119S' started by kenjancef, Mar 17, 2017.
  1. kenjancef
    kenjancef New Member
    12
    3
    Rhode Island
    Country:
    Dash Cam:
    VIOFO A119S
    Just got the A119S from CYA (thanks for the FAST shipping by the way!!) and I want to hardwire it into my 2016 RAV4's sunroof motor wiring. What do I need to hardwire this? is there a simple kit I can order somewhere? It would just need to be a VERY short wire...
    CaptureYourAction likes this.
  2. kenjancef
    12
    3
    Rhode Island
    Country:
    Dash Cam:
    VIOFO A119S
  3. CaptureYourAction
    CaptureYourAction Well-Known Member Retailer
    1,175
    417
    New England
    Country:
    Dash Cam:
    DOD, Dome Technologies, VicoVation, Viofo
    I know people do it, but I don't think it a good idea to splice into things like the mirror, moon roof...etc, when it's so easy to hard wire into the fuse box. The fuse box is usually pretty accessible and tucking the USB cable behind the molding is very easy in most cars. If you really want to do it that way, there is an item on Amazon that someone came up with to connect into the rear view mirror and I assume it would work with the moon roof as well. It's a little pricey since you'll still need a 12V to 5V converter, but at least you wouldn't be splicing wires.
    https://www.amazon.com/gp/B01AYS4JZ4
  4. BlackboxMyCar
    BlackboxMyCar Active Member Retailer
    230
    119
    Vancouver, BC.
    Country:
    Dash Cam:
    Thinkware, BlackVue, BlackSys , LG Innotek, VIOFO,
    That looks like a pretty annoying hardwire kit if the converter is only a foot from the plug, you'd need to stuff that in the headliner (should be doable on a rav4 but might bulge)
    It's also only about 4.5 feet long which isn't enough.
  5. jokiin
    jokiin Well-Known Member Manufacturer
    32,423
    15,640
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    the converter looks to be pretty small so would probably hide up ok, the downside though is that being small it is going to generate more heat than ideal for something tucked inside a roof lining and a good chance the design isn't well filtered so may induce noise, not a good choice I would think
    OCD Tronic and BlackboxMyCar like this.
  6. kenjancef
    12
    3
    Rhode Island
    Country:
    Dash Cam:
    VIOFO A119S
    Well the reason I wanted to tie off of a wire up there is that I didn't want to route the wire down the side of the window since I have airbags there. And from what I've seen so far in pictures, since I haven't removed the dome light assembly myself, it looks like there's room up there to put the excess wiring. If there is a lot of room I'd just buy the hardwire kit from CYA and use that. I just don't want to mess up the airbags...
  7. jokiin
    32,423
    15,640
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    yeah I understood why you wanted to use that one, airbags are no big deal though, just run the wires behind them, very straightforward
  8. kenjancef
    12
    3
    Rhode Island
    Country:
    Dash Cam:
    VIOFO A119S
    Funny... for the heck of it I tried running the cord that came with my camera, took 10 minutes to run it along the headliner, down the left side, and under the dash... lol. Guess I shouldn't have been too worried... I'm using the cigarette lighter plug for now, will probably hardware it with the kit and a fuse tap eventually.
    Thanks for the replies all...
    jokiin and CaptureYourAction like this.
Loading...
Share This Page
