Yeah parking is just every time you stop your car, night or day.
As i recently said elsewhere i would personally only use 30 minutes of parking mode after key off as that will cover all my shopping need, and at home i have CCTV on the car where it is parked, so no need for parking mode on the dashcam there.
So any longer period i might need a few times every year, and then i would just go into the camera setting and change the 30 minutes to what ever hours i will be gone from the car.
When you use the hard wire kit that open up 2 menus in the camera, they where still there before but just dident work with a regular power source.
But now with the hard wire kit you can go into those 2 menus and make changes.
In the first menu related to parking mode "
parking monitor" thats where you set the FPS the camera should use when parked, i am not aware of what options are in there, but i think i would like to use 5 FPS if thats a option.
Second parking mode related menu are called "
Shutdown timer", this is where you set the timer for how long the camera should be in parking mode, i assume the options are from "never" meaning the battery cut of decide when the camera stop, so that could be any amount of hours depending on car battery state and size.
And then you would probably have some settings which i guesstimate could be 5 minutes - 30 minuted - 1 hour - 3 hour - 6 hour timed shut down.
But as i dont have the hard wire kit i am guessing what the actual values are in those 2 menus.
I quickly skim those 2 parking mode related menus in my video about the DC menus, but thats also all i could do as there was no hard wire kit out at the time i made the video, and not much explanation as to what those 2 menu items was.
Perhaps one of the guys with the hard wire kit could enlighten me on what the actual values are in those 2 menus, and what setting are the default.
By the sound of it, it sounds like the default
Shutdown Timer are set to "never" meaning there are no timed shut off only the battery cut off, which as i understand it you have set to 12.2 Volts, so the camera will be in parking mode until your car battery reach 12.2 volts, or you start the car and go for a drive.
Like i said i would personally probably only use 30 minutes shutdown timer, so what ever i set the battery cut off to on the switch on the PSU dont matter much and will only be a safety making sure my car battery cant get discharged by accident.
So in general you have 2 options for parking mode, you can let the car battery voltage be the deciding factor on when the camera shut down ( 12.2 volts in your case )
Or you could use one of the timer settings and have the camera shut down after XX minutes or X hours ( what ever the values are in that menu )
Thinking back the past year i cant think of a single time where i would have felt like having parking guard on for a extended period ( i know i should get out more and rub shoulders with my fellow Danes )
But a timed option of 30 minutes will cover me at the store where i shop, and at the pizza joint when i go there to pick up bachelor dinner, and then maybe the occasional trip to the post office or shopping in a new place.
I am about to build a new computer, so that mean i will have to drive to local stores in the area to pick up hardware, but 30 minutes should also be fine for this.
