russ331
- Aug 10, 2013
- Kingston on Thames
- United Kingdom
- Mobius B (x2) & A119
Found some hints & tips for getting the most from this device...
'...update the firmware first. Make sure you are connected to the mains power for this.
http://www.kingston.com/en/support/technical/downloads?product=mlw221&filename=mlwfw_v1-1-4-2
Reading the review on Amazon there is mention of using the URL to access the device as the software is not great. Remember that the speed of the SD card and the Controller on the phone that writes to the SD card are likely to limit your speed. Also alot of HD video takes up a lot of space so copying the files even over a wired connection can take ages. Most Wifi (including the chipset in this unit) will also have a limited throughput, it is enough for 3 concurrent video streams but that is still not a huge amount and these devices are tuned for battery life not throughput. Also use Wifi Analyser free app on Play store to check the channels in use to make sure there are not conflicts and the wifi signal is not part of the problem. How big are the files you want to send from the phone to the device?. http://www.amazon.co.uk/Kingston-Technology-MLW221-Mobilelite-Wireless/product-reviews/B00CEB5QU2/ref=dpx_acr_txt?showViewpoints=1
This is a great accessory for travel. Charges from a standard usb charger, let's you backup photos from your digital camera to a usb drive, and most importantly it streams movies and tv to your devices - I've tried it with my iPhone and ipad using nPlayer. The supplied software works ok but has some peculiarities where you can't stream mkv's but can stream mp4s.. To stream an mkv I had to use the web interface (not really publicised, access from mobilelite.com) and then copy and paste the http URL of the file into nplayer. You can use "send to" with a variety of players but this forces the file to copy entirely before playing, not necessarily a bad thing but you might have to wait a bit before watching! The software allows you to navigate around both USB and as cards, a facility to more easily select a lot of files would be beneficial as backing up many photos can take quite a time to select multiple files. Recommended product at a reasonable price.
The reviews mention MoliPlayer for iOS and Android and nplayer on iOS. I have used MXPlayer for playing MKVs even DTS is supported but you need to install a custom codec for this (also free).'
