Mini 0803 coming
Good Day
I have tried a micro sd card and it worked but still no access to internal memory, the sd card info now comes up with codec errors on anything but the QTPlayer and cannot read.
Also in the menu on this 0803 with 16gb internal memory there is no option to go from internal memory or external memory like in the review I watched.
This thing came from Foxoffer with firmware version 20140511 v1.0
Not sure what to do at this point, might just send it back but then shipping to China will probably be as much as the camera.
I am starting to think that the firmware installed is for an 0803 without internal memory
Take care
Tatsudoshi - I'm having the very same problem. I went out yesterday and purchased a micro USB card (something I didn't want to have to do!) and, like you, the camera doesn't indicate that an extra card is there (no choice between internal or external memory). I recorded some footage then tried playing it back on my Windows 7 machine, and it came up with an error. However, when I tried my Mac, I WAS able to play the footage.
I e-mailed FoxOffer explaining the issue, but did not get a reply. Without being able to access the camera itself, or to view the external card through the camera, even if I get a new version of firmware, I don't see anyway I would be able to load it. I'm not happy at all with my purchases.
There is a known bug with different versions of FW not being able to see the internal memory when an external SD card is installed. 20140507 v1.0 is the last FW I am aware of where 2 cards are recognised.
Good Day
Well I was able to get playback off of my sd card via pqplayer but it is the worst video quality I have ever seen, set to s.fine 1080 and ev +1
Footage is so jittery even while not moving it gives you a headache watching it and has a constant loud hum for the sound, outstanding ...
I have e-mailed Foxoffer and am awaiting a reply.
I also must add that the unit was extremely hot after only 20 minutes of use.
Oh yea the GPS does not work either.
Take Care
Good Day
Take care
Try flashing the firmware using a MicroSD with a firmware for Mini 0803 with internal memory.
If you or giantbunnyhead do want to purchase another Mini 0803, maybe try us, we are located in Toronto. If you have any problems, you won't have to pay the costly shipping fees to sent it back to China.
We do not have any Mini 0803 with internal memory, but the extra cost for internal memory is the same as purchasing a Micro SD card elsewhere. '
Kelvin
Good Day
Well I flashed the memory with the last version of firmware that supports internal memory and GPS and she is pooched all it does now is the blue light comes on and that is it,no screen, zip. nada.
I guess I should have just thrown 100.00 out the window, it would have gave me the same result.
Live and learn.
Take Care Guys and Gals
Good Day
Live and learn.
Looks like you got a faulty one, RMA it and ask for a replacement the 0803 is a great camera.
Good Day
I am new here as well and am also having the same issue with my 0803 with 16gb internal memory when using the usb supplied cable, a blue screen saying usb connecting and that is it, cannot seem to transfer data to PC to view video.
I am going to try a micro sd card and see if that will work but still does not explain the blue screen with internal memory.
Take Care
Go to the Device manager and click Universal Serial Bus controllers to expand.
Right click on each entry and click Uninstall.
Reboot computer to reinstall drivers.
Plug mini into usb an pray drivers install.
Two different lenses? 😵
What are the differences :s
Different resellers. The one on the top if from Foxoffer (the one I bought recently).
The other one is from JooVuu (the one I ordered for a colleague).
they are from two different manufacturers, they source their cameras from different suppliers
Is one of the lenses better? 😀
I don't want to taint your opinion by telling you which I think is better but yes I do feel one gives slightly different results to the other, that can partially be firmware related though as the specs are different and what is required in the firmware differs as a result
How about you just tell us which one do you think is better 🙂
Tobi@s have you had chance to compare 2 cameras? Any difference?
Just did one, will maybe compare at night a second time:
Both devices use the same Firmware.
I don't see any differences in this one :S
