Number400
- May 5, 2014
- South Central PA
- Panorama S/CF-100/BulletHD Biker Mate
Since this is still an active old thread. My kids 3D printed me a side window mobius mount yesterday. I just love having cameras on all side
Looks to be a standard Mobius to GoPro mount, and from there I think I saw that end either in the Drone category or it was the featured customizable GoPro mount on Thingiverse.Interesting mount, have you found it to be stable under variable road conditions?
Fixed that for youWhat's nice is that anything can now be made [...]. I love our new hobby and look forward to getting better at design.
That is the mount that also originally came with the Innovv C3. You can sometimes find that mount on eBay.
(The DR-32 was made by the same company that became Innovv.)
https://www.ebay.com/itm/371635200917
Is this one better than the helmet mount?
Where's this helmet mount? Pics / Link?
I like the one Dashmellow made, although I would personally want a bit bigger diameter on the base for better security to the windshield to further reduce vibrations, but that's just me. I love how it enables really tight spaces, that one is going to see use for me unless this helmet thing is better.
Is anyone using the Mobius externally as a dash cam by the way? I swear I have the one edge case that nobody cares enough to accommodate, I am looking to put them in the rear side windows of my DeLorean, which is exposed to the elements on both sides of the glass it will sit behind. So it needs to be able to handle the elements (which Mobius is perfect for, but that USB might cause issues if not protected), and the glare is insane too, so a CPL would be needed (JooVuu X CPL might fit with tweaks). The requirements of CPL External cam is a unicorn it seems, nobody seems to cater to classics or exotics.
Thanks for the link! I may have to go that route unless I can figure out something better, given the other option is to mount on "bump" textured fiberglass, which is exposed to the elements and as a result has seriously undermined adhesive properties already.A photo of the helmet mount and a link can be found in THIS post.
As for my DIY ball joint mount, the thing has been rock solid for the last two years with 3M VHB tape and a Mobius attached. (as a side cam) Vibration has not been an issue. Also, the base of the DIY mount is made from a steel washer and so it can be easily attached to a strong neodymium magnet if desired. That works well too but I found I preferred the more permanent and secure 3M VHB tape method.
