Hello, I posted about this on RCGroups but since this is likely a different crowd I'm posting it here also. Apologies if most of you are also on RCGroups.
About a week ago my quad crashed and the Mobius fell off but looked and acted OK. When I went to review the next set of videos, however, all of them were severely out of focus. When putting some torque on the lens I felt some play so I took it apart and found that the threaded lens mount was cracked. Couldn't find just that as a replacement part so I decided to try gluing it with some CA. In order to do that I removed the lens, which was impossible to turn by hand so I used channel locks (yes I removed the lock screw). Surprisingly enough the fix seemed to have worked.
Next step was to get the lens refocused. I initially tried doing this with a 5" LCD and the composite output but this turned out to be futile due to the small screen. Next I decided to take pictures in 5 degree or so lens-turn increments and then set it to whichever position ended up taking the sharpest photo. Unfortunately next time I plugged the Mobius back into the PC I got the dreaded "unrecognized device" message. After some playing around it got even worse and the camera wouldn't turn on properly, only the blue LED would turn on or the blue LED and then battery status LED would turn on and go solid. The PC did recognize it a few times after that upon random connections but right now it's to the point where it won't even turn on any more. When I plug it into external power the green LED turns on so it's not completely dead. Battery is OK and I'm seeing 3.8V on the pins on the back of the PCB. PCB and USB port look fine based on visual inspection.
I'm thinking likely the ribbon cable which got stressed when I was cranking on the lens with the pliers? Even though I ohmed it out and it appears OK it could explain why things kept getting worse (more flex, more damage?)
Any other ideas/things I can try?
If not, where can get a replacement? Only thing I can find are the extension cables which I do not or want/need.
I only made about 10 recordings on it before this happened
