Welcome to DCT. Is your Mobius plugged into the 12v accessory socket (via 12v to 5v adapter) or into a USB socket in the glovebox? If the latter, then insufficient power to the Mobius may be the problem. Mobius requires 5v 1A & is intolerent of inadequate supply.
I suggest that you disconnect Mobius from external power, & record some video using it's internal battery. If it successfully records clips, then suspect the external power supply.
Just tried recording by itself with the internal battery and after about 4-5 minutes it just shut off and when I went to view the recorded file nothing is there. Just an empty folder.
Edit: I should also note, it's at full battery as indicated by three blinks of the red light when I power it on.
Edit2: Almost right at 5 minutes it went solid yellow light and didnt respond to any button presses. I'm guessing if I left it a little longer it would have shut off completely? Not sure on that part.
Forced it off by holding the power button and pressing the power button again after that turned it on with a solid blue light, still unresponsive to any button press after that, had to hold the power to turn it off. Which now made it unresponsive to even the power button so it just sits there bricked. And plugging it into my computer at this point gives a reading "The last USB device you connected to this computer malfunctioned, and Windows does not recognize it". The green LED is on at least though.
With it unplugged right now none of the buttons do anything, but as soon as I stuck a needle into the reset it operates normally. Also since this time I caught it during the solid yellow phase the recording actually saved and works. (It's 5:01 in length)
All of that happens every time I try to record something ^ Tried to be as thorough as possible explaining what happens and what I do during it.
Edit3!: Changed the loop duration from 5 to 3 minutes just to test some more and it got through three recordings, all 3:01 in duration before stopping and getting stuck on a solid yellow light like before.
All of the tests above are with internal battery to be clear, and it was doing the same thing with the external car usb as well.
