Hi Jokiin,have you opened it up or dropped it at anytime? Try reseating the CMOS sensor ribbon cable
Hi Jokiin,
No I haven't opened or dropped it. It's around two years old and is used as a dashcam on a daily basis. I did noticed that shortly before it completely failed the footage would flick erratically between light and dark.
it has a battery but runs off the car most of the time.do you have a battery or capacitors in it?
When turned on, either on battery or car power, it appears to be recording normally in that all the leds are blinking as expected.
When you power the camera with external power it doesn't matter that much if there's a battery or a capacitor in it, because in that situation they only serve to power the camera long enough to save the last file after you cut the external power source and keep the time and date. Capacitors are better for hot weather countries/regions because they're not affected as much by the heat as batteries, which tend to degrade over time, even if they're used only for that last file saving purpose. In Scotland the battery will last much longer than, for instance, in Australia, South America, parts of the USA, Asia, etc.Hi Dashmellow
I take it from this conversation that it is better to have a super-capacitor than a battery in cold situations. I live in Scottish Lowland and it does get cold but very rarely will it go below say -5.
but just the same my mobius after I have fully charged it in the house will work fine for a few days but then although the red light flashes 3 times it doesn't always start recording. Even when I press the power button it will flash 3 times but not always start recording. I was thinking that that it must be the cold.
Willie
Hi Dashmellow
Willie
I'm sure component quality would be as good as it gets but I wonder if things like the Tesla are affected by the extremes of temp, hot or cold, likewise their home storage battery solution?
I guess they would have thought of these things and have some sort of solution for it, not sure what that might be though, our concerns over batteries that top out at 1000mAh or so don't really compare but the tech is always interesting
The reason I quoted your post is to ask this:(...) one should never charge a frozen lithium-ion battery because it will become damaged.
When I had the Mobius here, the first time I connected it to a power source the blue light came on. I used it in the car for two days, so the battery was fully charged. After I took it out of the car it sat unused for a long time and everytime I connected it again to a power source the blue light never lit up, which indicated the battery wasn't being charged.
So, if the camera is left exposed to freezing temperatures overnight inside the car, turned off and with a fully charged battery, when you power it up the next day is the battery going to receive charge again? Is the Mobius battery always receiving charge, even when it's full, or the system only charges it when it detects the battery has lost voltage?
Or that. I didn't use it long enough to memorize the color codes.It is the green light that will indicate if the battery is being charged. It will turn off when the battery is fully charged.
I was speaking in general terms because the information might be useful to other members reading this thread.As to whether applying power to a Mobius that has a frozen fully charged battery in it is causing harm, I don't really know but my feeling is that it's probably not a good thing to do every day. If it were me I would just install a super-capacitor. On the other hand, since the battery is so easy to replace in the Mobius, if it suffers a little damage from how you wish to use it and it ends up with a shorter lifespan, you can just replace it. I think it depends on just how cold out it gets where you live. Where I live it easily can go down to WAY below freezing often in the winter time so I avoid using battery powered cameras unless I can bring them indoors overnight. With super-capacitors in my cameras both summer and winter it is one less thing to even have to think about.
