The question is not whether what you are seeing is UNSEEN. The question is what is causing you to see it. I think that you are seeing a color shift on one side due to something about your headlights but if you are not willing to do any definitive testing then it is a matter of what you "believe" over what "is". If you don't see any "Green Monsters" during the daytime, it is highly unlikely that you would have something other than an external light source causing it to occur at night only. I don't believe there is anything wrong with your Mobius other than perhaps unrealistic expectations.
You asked:
"I'd like you to show us some example screenshots of other camera's that show this exact same phenomeneon as proof for your diagnostic conclusion." Well, I already did that two weeks ago but you seem to want to ignore that. Here is the image again. It was from
@kamkar1's JooVuuX and in this case the so called" Green Monster" you see on the surface of the road is caused by a beam of light that has a CRI (
Color Rendering Index) in the green area of the spectrum as it appears to the CMOS in your camera.
I keep trying to explain how different light sources will appear as different colors on camera. Here is another excellent example of the phenomenon. The entire right side of the road has a "Green Monster". Of course, on the left is the "Orange Monster".
The only logical conclusion SEEMS to be the car's headlights, the green spot is there, and it's always on the same place, (it doesn't move with streetlighs passing by) but if you've seen the screenshots I posted earlier, then you can see the green spot even with the headlights off, so that still leads me to think that there is something else going on.
Headlights are actually pointing to the right side of the road though, to avoid blinding upcoming traffic, so maybe there is something in that too, although with headlights off I see the same, so..... I don't know man....
I could swivel the camera around a bit to left and right when at standstill with headlights on and off, to see if the spot stays in the same place on the screen or if it stays with the headlights or something else.
I didn't conciuously notice your earlier examples, but there the discoloring is indeed obvious with the streetlights, I have'nt noticed that with the mobius yet though.
Eletoponline365 offered me to investigate, but then I need to send my lens modules back once again ($$$$$), and they would crosspost me some new ones (which I have to pay $$$$$ for... and get credit when mine arrives at their office), I'm not doing that. The most logical way would be that they examine 2 or 3 lens modules to check if they are presenting the same kind of thing, and if not, send me the new ones for a swap.....
UNWILLINGLY I just have'nt gotten around to do the nightly whitewall test yet, but I will as soon as the chance comes up. (Is this also your idea of "definitive testing"?) I just need to find me some where I can test it ONLY with and without headlights at night, outside, ruling out streetlights.
Or is there another way to do a test? Indoor low light testing seems to be not a good reference to me.
I'd like to add that the camera is approx 20-25 cm from the winshield of the truck and the windshield is almost 90 degree vertical upright, so maybe placing the camera with the lens stuck right up to the windscreen might give a different result....
