Rob J
- Jan 19, 2014
- Southampton
- United Kingdom
- mini 0801/G1W-C/G1W-S/DP200/mobius v3 c2/A118C/Joovuu X
I mounted my mobius cameras all facing down (so a third of the field of view is dash as an example) to reduce facing directly into the sky etc that confuses the sensor. Also it reduces glare and any reflection and colour distortion. I did get green glares and all sorts if I recall correctly, but changed the camera angle during set up as I identified that being the issue right away. I also have a slight tint to my glass that would create this.
Setting are just standard WDR on 50mhz light frequency, immediate disconnect etc (supercap settings just like @russ331 posted before), 5 min MOV clips, 1080p res with high video rate, wide FOV and 30FPS etc etc.
As its FW 0.59, no advanced settings because you cant muck around with it and mess it up.
I have the same setup other than 3 min clips. FW 0.59 is the second best at night after 0.47 but had to settle for former as 0.47 won't work with the super capacitor.
