how long had the camera been running for in the first pic and how long running in the second?
For like 4 weeks then this starts happening.
I meant how long had it been recording for in each case, 10 minutes, 30 minutes, an hour etc?
in both cases?5 minutes
If you are asking settings it is 5 minutes.
For each time I record is for 30 minutes
in both cases?
Yes, I think it started happening since it fell off my dash
That's good info - just connect it up to your PC in webcam mode and refocus and it should be as good as new - sometimes even betterYes, I think it started happening since it fell off my dash
You didn't think it worth mentioning this in Post 825?Yes, I think it started happening since it fell off my dash
VITAL. like going into the doctor after you collapsed and nearly died and forgot to tell him you overdosed on methamphetamines while he is sitting there wondering what the hell is going on with you and what is wrong with you.
That could be a good bit of info!![]()
You mean #4?Maybe the focus has been knocked if it's been cleaned or something?
Might be worth checking this post in this thread:
#5
How do you turn it into a webcam? The manual is not very helpfulThat's good info - just connect it up to your PC in webcam mode and refocus and it should be as good as new - sometimes even better![]()
Could you please tell us why you don't find the manual very helpful. Maybe it could be improved?How do you turn it into a webcam? The manual is not very helpful
tia
Taken directly from the manual:
Webcam Mode
There are two ways in which you can enter webcam mode.
Method 1:
Method 2:
- Connect the camera as a removable drive (see above).
- Press the Shutter button to enter webcam mode.
- ► If this is the first time you have connected the camera in WebCam mode, Windows will automatically install the required drivers.
- ► Disconnect the camera or press the Power button to exit webcam mode.
►Note: Windows XP has an integrated WebCam viewer. Your Mobius should be visible in Explorer (My Computer) as a "USB Video Device". This functionality does not exist in Windows 7.
- Remove the flash memory card.
- Connect the camera to the PC using a standard USB cable.
- The yellow LED will blink at 2 second intervals indicating there is no card inserted. This is normal.
- The camera is now in Webcam mode.
- Start your favorite WebCam software, such as AMCap. If your screen is black, the software is not configured correctly. Make sure the program shows the "USB PC camera" as the "device" selected for video capture. If this option does not show in the "device" option list, restart the webcam program and check again.
- Disconnect the camera or press the Power button to exit webcam mode.
