- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
in the interim I think I'd just run it with the battery if that works reliably
will this make any difference for a dash cam use? where the power buttons never get pressed?Power On change from Delay to Fast
On second thought, maybe you're rightwill this make any difference for a dash cam use? where the power buttons never get pressed?
If you would post your SYSCFG.TXT file I could see if my camera performs similarly, but you would have to give me a few days. I really need your SYSCFG.TXT file in order to load the exact same parameters as you have. Since SYSCFG.TXT is a text file you can simply copy/paste the values here. Posting screen shots is not enough. I would then have to know the exact steps you took. You may have a bad capacitor or there may be an out-of-spec component in your camera. I think you mentioned the camera didn't lose it's date and time which indicates the supercap is OK. Even if the camera doesn't start properly, can it keep it's date and time for at least a week? If yes, then chances are pretty high that your supercap is OK.still happening, very consistently, leave 2 days then power up it doesn't record. Isoprop, can you reply to my problem with your thoughts on this, the camera wont start recording again until the capacitor has reached full charge. then when you power cycle it starts recording straight away. is this normal or not? if not how to fix?? all my settings are on the previous page.
here is the config file.If you would post your SYSCFG.TXT file I could see if my camera performs similarly
Hello everybody ! I owe you my Mobius state ! Very confusing !!!! After the above written failure , I successfully charged (aprox 3 hours ) it . I formatted the card again with SDformatter . I recorded normally 1 hour ( only with its battery ) . Next time , when I wanted to use it again , same signs : rapidly yellow blinks , three red blinks and then the camera shut down . I tried power it on again after a few minutes and it worked properly again !!! For now it is charging but when I plugged it in , the secvence was : green led and overwritten , yellow blinking again , followed by 3 red blinks and then continuously green . I am waiting for it to full-charge . What do you think might have caused this hazardous behavior ? Normal function for 1-2 hrs of recording and then the "yellow sequences" again. I am trying not to send back to eletoponline365 because of the long waiting time and maybe it can be fixed here. Thank you Jokiin , Isoprop , GJHS and other helpful users !Hello again ! I get back with my wish , about a possible solution for my Mobius failure.. I make a request to Isoprop or Jokiin - if they have a little time - for my question . My Mobius , discontinuous ( I mean between longer or shorter recordings ) has periods of nonworking : after pressing power button (blue , followed by continuous yellow ) , press shutter button -----> rapid blinking of yellow for 5-6 seconds , following a few red ones , yellow again continuous for 2-3 sec and stop . I have learned a lot from this excellent forum about the ,,claims'' Mobius has to have for a proper functioning ( Kingston 32Gb 4 class , Min 1 A charging device , good cables , etc ) . I did not make any update of the original firmware ( 10 months ago ) . The battery charging and the levels of charging seems to be OK . I have another Mobius with an original Kingston microsd 32 gb from same seller ( apropos -eletoponline 365 is a very professional and prompt seller ) , I have tried with this one , but same result.. Thank you in advance for your time .
Rapid yellow blinking means there's a card-related problem. In most cases there's a problem with the card but there could also be a physical failure like dirt in the card cage, dirty contacts on your card or even a bad solder joint on the cage itself (extremely rare).Hello everybody ! I owe you my Mobius state ! Very confusing !!!! After the above written failure , I successfully charged (aprox 3 hours ) it . I formatted the card again with SDformatter . I recorded normally 1 hour ( only with its battery ) . Next time , when I wanted to use it again , same signs : rapidly yellow blinks , three red blinks and then the camera shut down . I tried power it on again after a few minutes and it worked properly again !!! For now it is charging but when I plugged it in , the secvence was : green led and overwritten , yellow blinking again , followed by 3 red blinks and then continuously green . I am waiting for it to full-charge . What do you think might have caused this hazardous behavior ? Normal function for 1-2 hrs of recording and then the "yellow sequences" again. I am trying not to send back to eletoponline365 because of the long waiting time and maybe it can be fixed here. Thank you Jokiin , Isoprop , GJHS and other helpful users !
forgot to mention V2.18 firmware but its in my other posts.I don't have a camera stamped 28-2-14 so I'm using an earlier version.
One small detail, but I don't think it should make a difference, is you should safely remove (eject) your camera and then press the power button before disconnecting it from the PC. I'm following your instructions exactly, so I haven't done this.
I'll post my results in a few of days.
