That is a valid point, and even more of a reason to keep clear records of problems that the dashcam community are having with the Mobius.Their main focus/market will be mainly RC related. I think the reason they switch to plastic/fibre is to keep the weight down ( bigger battery/ possibly heavier lens C). And heat is not a RC issue.
I can't give you an answer on that because I don't know. However, the question has been posted a number of times over the past 2 or 3 years (including #16 posts) so I'm sure it's been noted by the developer.@Isoprop is it possible to do metering modes such as average, center and spot?
The RC folks would prefer a 'bottom' metering, but others want a left corner, right corner, top or center metering! I don't know how practical these settings would be for a camera without a display, but I can imagine the developer may have tried different metering modes, if they are supported by the DSP, and abandoned them because they didn't work to his satisfaction. This is purely an assumption on my part.
I think these settings, and more importantly the improvement they might offer, is very subjective
Do you mean the firmware itself is far more important than any user settings you can change?
Here are 3 PNG screenshots from VLC, exported with MS Picture Manager as JPG with quality setting set to 100. Original screenshots were to big to upload here.Regarding the focus problem I will properly test it this weekend by this scenario:
- park the car in shopping center with close and far scenery
- turn on the AC towards windscreen
- record for few minutes
- turn on the heat towards windscreen
The results I think should prove if there are any problems.
17:11 camera was running for about 3 minutes, outside temperature 12 degrees Celsius, but the car was parked inside, not in the sun. At this moment I turned AC on with the airflow directed to the windshield (and camera)
17:18 after 7 minutes with AC on, it was pretty cold in the car. At this moment I turned the heat on.
17:23 after 3 minute with heat on
Beside that I ran other static tests each day as my Mobius power is cut 30 minutes after locking the car. My personal conclusion at the moment is that there is no focus shifting caused by the heat and the new material used for the lens module. I know how focus shifting looks from my 808 #16.
BUT... the C lens problem I think it's the contrast, again it's my personal opinion. In areas with high contrast like buildings or trees in bright sunlight the objects look unfocused, while the rest of the picture looks good. You can notice this effect also in the images attached, on the side of the building. It gets worst while in motion.
I'll try this week to compare this against a Mobius B, because I didn't noticed this problem before switching to C lens.
I spent some more time trying to focus my C lens. I finally managed to get it marginally better.
As mentioned by someone else, the grub screw had been over tightened at the factory and deformed the lens barrel. I don't think I will get it any better without resorting to drilling out the damage or forcing it with pliers.
Also of interest is the lens ribbon. It has damage on the lower section from rubbing on the small plastic rib, and I'm not sure what is going on at the top, it could be poorly applied paint or damage from rubbing on the case.
The lens ribbon is a little worrying considering the camera has less than 10 hours of use. Hopefully with the rib modified the ribbon will fit properly.
Did you removed the lens completely? I had the surprise to notice that the hole is not complete, so the screw doesn't tighten directly the thread on the lens barel (you can;t see it through the hole), but it's tightened on the exterior of the thread in which the lens is screwed. Even though I cleaned the hole and the threads I'm still not able to adjust the focus easily, which made me think that either the module is to tight for the lens, either the thread is not deep (long?) enough.As mentioned by someone else, the grub screw had been over tightened at the factory and deformed the lens barrel. I don't think I will get it any better without resorting to drilling out the damage or forcing it with pliers.
No, I haven't removed the lens, even when using extreme force it can only rotate <1mm in either direction from where it came set at. To get it to rotate anymore will require pliers.Did you removed the lens completely? I had the surprise to notice that the hole is not complete, so the screw doesn't tighten directly the thread on the lens barel (you can;t see it through the hole), but it's tightened on the exterior of the thread in which the lens is screwed. Even though I cleaned the hole and the threads I'm still not able to adjust the focus easily, which made me think that either the module is to tight for the lens, either the thread is not deep (long?) enough.
If it's not clear what I wrote, I'll try to open it again and make some pictures.
Can I change my mind?My personal conclusion at the moment is that there is no focus shifting caused by the heat and the new material used for the lens module.
I wonder if the new anti-flare coating on the lens is sensitive to heat.
Thanks to my wife I had the oportunity to wait in a parking lot for about one hour, outside temperature was 18 degrees Celsius and the sun shining brightly. Both cameras (B and C) were recording all the time, bellow you can see what happened in 1 hour:
And this is a full screenshot from Mobius C (I was stopped at the red light, so no motion involved):
I won't even bother making a comparison movie, for the moment I'll switch back to B for the front camera. Maybe I'll try to put the C lens in the metal module of the A lens, but not in the very near future, so at the moment no more C topics from my part![]()
