Necromancer
- Sep 30, 2013
- Israel
Would a capacitor allow to save the date & time?
ours are 2.7v caps (in pairs to make 5.4v just like that one you listed is under the cover) and 15F each, most use at least the one pair, we're using two pairs so we have a bit more power in reserve
Are you allowed to say what camera your company manufactures? Just wondering...
I don't use my Mobius as a dashcam, but I would like to put the info about using a Super Capacitor in the Mobius straight. For the time being, the info below should be treated as "experimental".
It is possible to use 2 x 5F 2.7V Super Capacitors wired in series which equates to a total capacitance of 2.5F. This is a direct replacement for the battery and will fit nicely into the Mobius' case.
The date and time will always be lost when disconnecting external power because the Super Capacitors can't keep the RTC (run time clock) running for very long.
The configuration is stored in NVRAM (non-volatile RAM) so it will never be lost.
Using a Super Capacitor is not supported in the current firmware release. As soon as power is removed the camera must immediately save the current recording and shut-down. It must do this before the Super Capacitors discharge. This functionality requires an additional parameter which will possibly be implemented in an upcoming FW release.
It is likely that the official Chinese Mobius sellers will offer the Super Capacitor pair for sale, but I can't guarantee anything. Asking won't hurt.
Good to see you joined this forum and ready to share info we all need. On RCgroups you do a great job. It is hard to follow two forums at same time. "We" dash cam users have some times different needs, so your presence here is much appreciated.
I wish Tom also could join this forum and participate in Mobius discussion. We can learn a lot from you both.
Thanks for the good words. I don't use my Mobius as a dashcam so have no experience in this area. Most information about the Mobius can be found on the main RCGroup thread http://www.rcgroups.com/forums/showthread.php?t=1904559&pp=100 but if there's a specific question, like about the capacitor, then I'll try and reply as best as I can. I can't imagine RC users have any interest in a capacitor, so discussion over there is off topic anyway
I have to admit I was impressed how well the capacitor performed in my Mobius and can well imagine it could be useful in warm environments where the internal battery has to be protected from excessive heat. With the Supercaps mentioned, there is plenty of time for the Mobius to save the current file and shutdown correctly - at least in my short experiments.
From you last words I understand that you have already replaced battery for capacitors, right? What exact ones you used?
You and Tom have more influence with convincing a manufacturers. Please ask them to take a look into this forum so they will realize that Mobius being as dash camera actually has 100s times more potential to generate much bigger sales than if only ( mostly ) positioned for RC market, if some issues will be solved or even separate model with capacitors will be developed.
My proposals on what need to be done for Mobius to be most popular dash cam.
1. Capacitor instead of battery.
2. Adding motion detection recording / auto parking mode.
3. Firmware tune up for better night performance.( check my post #222 for video comparison ). Mobius has similar hardware as dod ls300w, nt96650 + ar0330, so in theory it has potential of better night perfirmance if firmware is correctly tuned up.
Day time is better than ls300w. I will post side by side video soon.
Yes, for testing purposes I have replaced the battery with a Supercap pair as described in my post #237. 2x 5F @ 2.7V in series.
It was your comparison video, notably the low-light differences, that led me to this thread
Please don't ask when all this will happen. Nobody knows. As in any such complex project, development can take a lot longer than expected, especially when unforeseen issues appear. This is inevitable.
- The developer is aware of point #1.
- Motion detection is planned for the next major release, but we are far from that release at present.
- Not sure what you mean by "auto parking mode", but if you mean the camera should continue to record after you turn off the ignition, then yes, this feature is known to the developer.
- As Tom has posted many times in his RC thread, tweaking the colors, WB etc. is an on-going process. This is proving to be very, very time consuming but is still planned for the next major release.
A minor FW release with better support for the new wide-angle lens and an additional parameter or two is expected soon. Tom has mentioned this too.
It will always be Tom who announces new functionality in his RC thread first. I may follow up if things aren't clear.
In the meantime there are so many threads on the Mobius that it's all but impossible to follow them all. However, all the important information seems to find it's way into the RC thread, which the developer follows very closely. He also takes dashcam functionality seriously but the Mobius can't do everything perfectly. A good example is using the Mobius in extreme temperatures. This will never work properly because the Mobius is designed to be small and compact. If the Mobius is expected to work in extreme temperatures then some form of active cooling will be necessary. As an all-round cam, the Mobius can't be beat, IMO.
Panorama 2 consistently look brighter in both day and night video, even though all three cams are set on default EV 0, it seems Powerucc has adjusted Panorama 2's default exposure brighter than most cams, some of the sky and clouds appear blown out white.
Mobius is a 5V camera, so the received power is always the same (I think) no matter if the car engine is running or not. In this case the solution could be an G-Sensor but I think now is too late to add something like this. I had some dicussions and ideas for the developer some time ago, before releasing the Mobius and maybe some of them are in the actual camera. In my brain the G-Sensor was the simplest idea to implement the auto-start of the camera or the parking mode, because when a car is running the G-Sensor is feeling this and in Parking Mode can detect a shock and also the Motion Detect (which is available in 808 #16) could be made depending on G-Sensor values.After you turn on ignition, camera "feels" higher voltage impulse and switches back to normal recording mode.
My simple idea for more brightness during night was to let user set in the GUI from which hour to which hour is night, save that value, and camera to increase the brightness for that hours. The bright value is not an absolute value so during the transition from day to night the video will be not very affected. But the user will need to adjust this value 2 or 4 times/year.
A more complicated idea was the user to enter his location from a list and the camera based on some already known values for all locations in the firmware, to automatically adjust the brightness.
Even this idea is actually used by some dashcam in some form, I had this idea before any dashcam in the world.
enjoy,
Mtz
