Hi JOOWUU
I think your extention usb cable should be waterproof on both side....one in the casing, n one out...
+ I think the out plug should be a female USB (waterproofed) so that we can add any standard male usb plug in, to fit any setting that we may have....for external battery packs.
For exemple, with my setting on the motobike, your USB cable (part of your new rear waterproof casing) is much too short for anything I may have external to connect the Mobius to.....I have a 1,80 meter USB cable to go to the external battery pack....
Either you do a waterproof rear end that does accept any mini USB plugs, so that we can fit ours in....or you do a USB cable out of the rear water proof casing that has a female USB plug (that will waterproof any USB standart plugs that we'll fit into)......If you see what I mean ???
Beside that (and out of subject here), I would not refer to the casing as WATERPROOF for DIVING.....there are too many weak points on the casing by which water pressure and mouvements (in the water pressure) will snap the casing in two parts open.....because your waterproofing relys ONLY on a TINY little rubber joint that is between the two thin faces of the casing thightened up together by 2 weak clips, which means, one tiny hair, grain of sand, or else on the rubber joint and that's it, the water will find a way to flush in....
+ as there is no ridges to strengthen and double the sealing, water pressure will snap it open quick...
That is my point of view, I would never take it underwater with the MOBIUS in.......
Even waterproof casing with a door (having ridges) that strengthen the seals, they often end up leaking too....Divers say..."" a waterproof casing is never 100% waterproof, it may be allright for 10 dives, then the 11th it will leak.....In fact it is not a matter of knowing if the leaking will occur, it's a matter of when it will occur....Water's nature always tend to reunite itself to itself """
And, your casing is far from being yet enoughly well ingeniered to support multiple dives....I am not an expert, but I give it 5 meters deep once to snap.....and breakup.... maybe not 5 meters.....
Please let me be not misanderstood here, It's not a bad criticism from me just for the sake of it, it's only a friendly warning for you so that you either improve the sealing on the casing more thightly and firm than it is right now, or you refer to your casing (for the buyers) as weather proof only (humidity, rain n so on) but in no case waterproof for diving with it.......
Except from all that I said (don't take it badly pls), thanks for your good works around the mobius camera....Sure good idea with it's rear end water proofing the mini USB plug, it will be fine for a motorbike dashcam....I'am already using it as such (praying it does'nt rain, so easy, in southeast of France we do not have the British weather, heheheheee), because I plug it without the rear end of the casing right now..... Note for others bikers, I made my motobike dashcam, of the MOBIUS, following the model of this guy
http://dashcamtalk.com/forum/thread...ration-system-for-a-motobike.5611/#post-66027
