- May 14, 2013
- Oakland Park, Florida (USA)
- StreetGuardian.CAM Amazon.com
Panorama X2 firmware 1.02.04
-Power Control Re-Calibrated/Measured Voltage Values raised to match closer.
-Increased Stability
1) Download 1.02.04
https://www.dropbox.com/s/cdl8enirm3jzujr/DHD_FullBurn.ELF?dl=1
2) Copy "DHD_FullBurn.ELF" to the root of each microSD card. (meaning not inside any folders)
3) Insert the microSD cards into your Panorama X2
(Important, your vehicle's engine must be running to ensure power is stable! Do not perform the update with the engine off)
4) Navigate via the easy to use touch screen to settings, "about" page, and press update!
5) Watch the progress bar fill up, when it's done it will shutdown/reboot.
6) You will need to change the language back to English using visual icons alone since it will be in Korean
7) Remove/Re-Insert power cord at least one time, and Format both cards using the settings menu in the camera at least once after you're done with the upgrade.
Below is step-by-step video on how to update a firmware on Panorama X2. (thanks @niko)
Note: This video was created before the latest exFAT support. You'll notice this video asks you to format the cards in the computer first. After 1.01.09 or above, there is no need to format cards in your computer any more. Just follow the video example so you know what to look for using the steps above.
The firmware prior to 1.02.04 was 1.02.03 1.02.01 & 1.01.09 (all previous fixes and features carried over)
I confirmed on the Bench, Power Control set to 12.4 V cuts off much closer to 12.3/12.4 than previous firmwares.
The small team of Beta testers are happy with the results so far. I wanted to test a bit longer but I'm ready to fast track this to the public area.
If there are further parking mode to driving mode problems, we have early ideas that using MLC based cards vs TLC will increase long term stability even further. (more details to follow on that)
![GQCVeMfl.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FGQCVeMfl.jpg&hash=7ce74e1b69257f27be20fc13d5732f7d)
1) Download 1.02.04
