I had the issue with 1.02.03 here today where it was totally dead when starting the car - pulled the cable for ten seconds and replaced and it powered up and worked fine
Un bricking would easy if you can get to the boot loader. Since there is no buttons or usb port how can you get to the boot loader? Just curious. Do you need to put a header on the board and use some other software and a dongle?Buttons or not this is still an issue if you brick it
If it bricks whilst updating the firmware and you've followed the instructions, is that covered under the warranty? I only ask coz every time I've updated the firmware it gets stuck on the first attempt and then I have to pull the power and try againNo it's not supported, if you brick it it's a brick
Great question.If it bricks whilst updating the firmware and you've followed the instructions, is that covered under the warranty? I only ask coz every time I've updated the firmware it gets stuck on the first attempt and then I have to pull the power and try again
Really? I could understand if its a non approved firmware, but I understood these to be official updates, so in all honesty they should be covered. For your benefit and ours.It's a grey area as far as me getting credit from the factory so be careful everyone or I get to eat it..
