Why do you want an alert when the camera starts recording over old files? Do you want to stop recording and insert another card?Viofo, please, can you add new functions to firmware? Can you add sound signal BEEP (or other sound) when sd card free space ends and device begin re-write old records on sd card??
Thanks!!!!!!!!!!!!New features like OSD OFF and LED OFF option can be supported in V1.6 firmware.
You right:Why do you want an alert when the camera starts recording over old files? Do you want to stop recording and insert another card?
Today I permanently connected the camera to the car's display. I only have a video signal connected.New features like OSD OFF and LED OFF option can be supported in V1.6 firmware.
This is the last option that would make the camera fully functional as a reversing/parking system.
I think so
does it reverse the display only, it still records the right way around?I have V1.5 beta firmware with this option
I recall only 5, 10 and 15 seconds. In the A119/A119S firmware at least. Maybe there was an off setting in the A129?From what I remember, Off was always there, Off, 5, 10 and 15.
I think it was 5, 10, 15 on the A129 too. That's why the 'Off' option stood out when I saw it yesterday.I recall only 5, 10 and 15 seconds. In the A119/A119S firmware at least. Maybe there was an off setting in the A129?
The AV out cable also support audio output while the camera playback the video.Today I permanently connected the camera to the car's display. I only have a video signal connected.
Is it possible to make the sound still be heard from the camera?
I think so
I don't have the possibility to connect audio. Can you add the audio option from the camera even though the video output is connected?The AV out cable also support audio output while the camera playback the video.
I would think this is not possible, maybe you could explain what this would be useful for???I don't have the possibility to connect audio. Can you add the audio option from the camera even though the video output is connected?
L | Parking mode only lasting a minute... settings or a bad HK3? | A129 / 129 Duo | 3 | |
M | Best parking mode | A129 / 129 Duo | 2 | |
Parking mode power consumption | A129 / 129 Duo | 17 | ||
U | A129 Duo No Longer Recording in Parking Mode | A129 / 129 Duo | 2 | |
J | Viofo A129 Duo Parking Mode Problem - Please Help | A129 / 129 Duo | 11 |
