Powerucc Panorama S
Is it correct that shpkorea at ebay is actually selling now the model with the magnetic ring? And where can I buy the suitable CPL filter?
Correct.
  • Like
Reactions: KvR
First impressions of the Powerucc Panorama S
Registrar looks with polarized filter.
http://i062.radikal.ru/1405/a9/abf635821981.png
All content is neatly Packed in cellophane.
http://s019.radikal.ru/i604/1405/a4/7ecd33c14e9f.png
The Registrar is located in a special soft rubber casing,
white instruction in Korean.
http://s020.radikal.ru/i719/1405/87/d1baad91ee91.png http://s020.radikal.ru/i711/1405/aa/8ccf0dd85ad3.png http://s020.radikal.ru/i721/1405/bf/4eb67e024c79.png
The Registrar - gloss black, looks nice.
http://s020.radikal.ru/i721/1405/f4/6de4f411131e.png
In the complete set there are two types of mounts. One rigidly attached to the glass with 3M adhesive tape, the other in the form of a vacuum attachment.
http://s58.radikal.ru/i162/1405/c7/c13a22239f50.png http://s018.radikal.ru/i527/1405/95/cd3faed18955.png
On the right side of the registrar is a slot for a memory card. On the left side a power input, input for external GPS sensor and video output.
http://i065.radikal.ru/1405/4e/e2e37202c192.png http://s43.radikal.ru/i101/1405/f0/6de85b6aa976.png
Here is theaccessories(GPSsensor,a polarizing filterandpower control unitfor the machine)
http://s018.radikal.ru/i518/1405/eb/3d404969c4c2.pnghttp://s017.radikal.ru/i444/1405/07/139711d12727.png http://s018.radikal.ru/i515/1405/4f/c52b3f405fda.png
The device is very liked in life he looks better.
I have to ask because I don't want to put wrong firmware to my new Panorama S (2014 model). It has now v1.12.04 firmware and recording @ 12mbps. And blue led in front is on.
I would like to have firmware that it records @ 21mbps and blue led in front is off. And G-sensor would be calibrated because now it is too sensitive even in low setting.
There are different threads with different firmwares. So what is the right one for Panorama S (2014 model)? Newest firmware... :)
http://dashcamtalk.com/forum/thread...firmware-12-15-21mbps-bit-rate-v1-12-03.4651/
Thank you, sir!
Is "how to upgrade firmware on Panorama2" same to Panorama S (2014 model)?
Yes, exactly as the video at niko
I see Roadcam announced this model as available now in the USA, http://dashcamtalk.com/forum/thread...powerucc-panorama2s-cpl-new-custom-dvrs.4872/ price is not much different to previous models actually so even though you're in the UK it doesn't look like much of a premium for the new version which is good so I'd expect this model should cost you much the same as the old version would have
I have patiently waited another month, we're in May and I have five weeks left before I drive down from the UK to the South of France for a well-earned holiday.
As I've not heard anything about the new Panorama S with GPS and CPL filter being made available here in the UK, should I now accept I'm not going to be able to order and receive the camera before my journey?
Just order it and use it. I think there is far too much hype about the CPL filter. The Pano records beautifully without it. Plus you have to take the CPL filter off for night driving. Once the novelty of a dashcam wears off you won't want to mess with it on every journey.
And I don't think so.
Have experience constant use filter BlackVue DR550GW / DR500W and now Panorama S
I'm not convinced that removing it is necessary. Niko has told me that turning it so that the polarizing effect is minimized will suffice. Not going out at night much,
I have tried that.
david
Has anyone from the UK ordered the S with GPS and CPL filter via the States distributor?
If so, can you please advise what the total cost was (including customs duty) and how long it took to get to you?
Today I got this camera and have some concerns.
1. My Sandisk Ultra MicroSDXC 64Gb does not work. I can't even format it. It works perfectly with my laptop and Galaxy S4 and worked properly with BlackVue DR500GW. Same model, but 8Gb works just perfectly with same adapter. Also Kingston full size SD 16Gb works perfectly.
2. Touch type is resistive. It is ok in cold conditions, but it seems not responsive enough.
3. When I push screen (normal use), left size goes down for about 1mm, sometimes with some sound.
4. Didn't find suitable place on the shield yet. Previous camera was behind the mirror, but this one does not fit there. On the drivers side it just does not fit, on the passanger side it fits, but I can't see screen. In case I suite it lower, it becomes well visible from the outside.
5. I didn't find separate G-sensor settings for parking and normal modes. Is it even there? Is there any settings for motion detection instead on/off? Here I should note that I was playing much with memory cards, and didn't check PC software yet.
6. At least two times it was absolutely frozen. It seems it was because of playing with memory cards.
Micro cards don't work well in Panorama cameras, and are regarded as BAD News. see
david
